Replacement Plastic for Alta Redshift Models
Status
Not open for further replies.
Elite Motorsports
Colorado
I get calls about Alta Plastic pretty often so I thought I would post the part numbers and current pricing here. Keep in mind that pricing could change and I may not be able to update this page to reflect that.
2017 MX Plastic (Gold)
6100330-00 - Front Fender Gold $32.99
6101654-01 - Front Number Plate White $27.99
6101554-00 - Shroud L/H Gold $31.99
6101553-00 - Shroud R/H Gold $31.99
6101218-00 - Decal Alta White L/H $17.99
6101208-00 - Decal Alta White R/H $17.99
6101440-03 - Mud Flap $39.99
6101445-00 - Rear Number Plate White R/H $21.99
6101441-00 - Rear Number Plate White L/H $21.99
6101439-02 - Lower rock guard Black $23.99
1201215-01 - Subframe Core Structure White $152.99
6101222-01 - Rear Fender Gold $54.99
2018 MX/MXR Plastic (White)
7503907-00 - Graphics Kit MXR $89.99
6103239-01 - Fender Rear MX White $58.99
1201215-02 - Subframe Core Structure White $152.99
6101556-00 - Shroud L/H White $31.99
6101555-00 - Shroud R/H White $31.99
5203182-00 - Fork Guard Set White AER $35.99
6103185-00 - Fender Front Large White $41.99
2018 EX Plastic (White)
5200085-00 - Fork Guard Set White 4CS $35.99
6103742-00 - Hand Guard Set White $54.99
6103185-00 - Fender Front Large $41.99
3900056-01 - Headlight Assembly $50.99
1201215-03 - Subframe Core Structure White $152.99
6100689-02 - Fender Rear SM/EX $72.99
6103102-00 - Tail Light Support $38.99
6103104-00 - Tail Light retainer $9.99
2018 SM Plastic (White)
6101449-00 - Fender Front SM White $31.99
metallic88
utah
do you know if there is a black set of these for the 4cs or do the ktm ones work?
also are there any black plastics available for the alta?
Thanks
metallic88
utah
The '14 EXC KTMs that came with 4CS forks should have the same fork guards.
You might have to buy a black graphics kit if you want to make your whole bike black.
I thought about it when they were yellow, but since i got a white one I like it. I was just curious if there were any, but i would like black fork guards eventually.
Thanks
flintpunk
Flint, Michigan
Man, I’d really like either a red or a blue rear fender. Then I could do either a Honda or Yamaha fender up front and have a red, white, and blue bike! Murica!
maybackgl
Brevard NC
How can I order replacement for the uncomfortable tanks side plastics? Thanks in advance!!!
QuinnShields
Massachusettes
is this item still available?
For future reference, Elites inventory is non-existent at this point.
@Matt by highly doubt I really think you really mean not a chance 😂.
The right side plate is the hens teeth of Alta plastic. If you still have the outer panel and have access to a 3D printer, I had created a piece that can be used to reattach the plate to the bike.
If it’s missing altogether and you don’t need number plates, you could consider removing both sides as many owners have done. It doesn’t look bad at all this way.
synics
New Jersey
Do you still have the right side rear number plate?
Status
