Redwolf
My dog thinks I'm cool
- Brinnon, Wa.
You could also use an engine hoist at home. This one is a steal for $59 shipped, equipped with a leveler:
Pittsburgh 2 Ton 4000 LB Load Leveler Engine Hoist Shop Jack Lift Cherry Picker for sale online | eBay
OOPS! Hoist not included, LOL!That’s for the leveler only.
I have a Honda 5000 with a perimeter frame and wheels. I was alone and faced with loading it by myself. I found that it slides up and down the ramp quite easily and steadily. My ramp is an eight foot by 10" with a slight arch in it. After loading and tieing the bike, I can push the gen up or pull it off, using a tie down to cinch up as I push to save ground gained if on an incline. I also thought that I could use my handy come a long tied on the bike to pull up if I was too tired. Turning most gens sideways, you can do the same. Much easier in practice.
I wanted to say that the weight of a 3300 W inverter is 64 lbs (not 50 as I wrote) but the weight of a 4000 W inverter which you need to be able to use the rapid charger is 100 lbs+ and in that case you need some help to load and unload..This is incorrect. The different is between the slow charging from 110V and the fast charging from 240V. You can run either the standard or the fast charger from 110V or 240V. However, charging from 110V at the track is so slow that it doesn't make any noticeable difference whether you are charging between the motos or not. In order to be able to ride all day you have to have 240V and a larger ~4000W generator.
But you are in Czech Republic... so I am confused. You don't have 50 lbs inverter generators there that can power the standard charger at 220V, do you? It would have to be rated at almost 3,000W.
Wow, that's light! And it should be able to charge the bike from empty to full in 2 hours with a Standard charger.I wanted to say that the weight of a 3300 W inverter is 64 lbs (not 50 as I wrote) but the weight of a 4000 W inverter which you need to be able to use the rapid charger is 100 lbs+ and in that case you need some help to load and unload..
Bike Ramps and other loading tips | Hauling your dirt bike | 35 |
