Caryder
- Phoenix AZ
Pretty! Thank you for the Forum props!
I really like the look - maybe a white or blue seat cover could be next.
What tires are those?
I like the grayscale look. I vacillated between bright or subdued. Went with flashy, which isn’t everyone’s cup of tea. Was originally thinking of Penton green w/ yellow mid 70’s style.Here’s my EXR with graphics from FX - I love graphics it’s fun and everyone has different concept
+2I would recommend getting a second Alta so that you can have 2 graphics sets - it only makes sense
Actually I did the subframe in a spray wrap just to test the waters. I’ll most likely peel it off and look into a more permanent solution, as I doubt it will hold up what I’ll be putting it through. I may end up going with some sort of duracoat or dip, or maybe even spray paint for plastic as a last resort. I’ll be researching my options while I’m testing the spray wrap. If anyone has any suggestions, please chime in!Installing the graphics on the sub frame must have been a lot of work - it worked out great - was it time consuming
I like the black subframe. Looks stealthy! The black color really accentuates the Alta's design with its minimalistic rear subframe the only function of which is to hold the seat and the rear fender. There is nothing else there, and the black color shows it very well.I just installed a new graphics kit on my 19 MXR. I’m really liking the look of it now.
You can use a thin 3M vinyl. It is super stretchy and sticks with no bubbles.Actually I did the subframe in a spray wrap just to test the waters. I’ll most likely peel it off and look into a more permanent solution, as I doubt it will hold up what I’ll be putting it through. I may end up going with some sort of duracoat or dip, or maybe even spray paint for plastic as a last resort. I’ll be researching my options while I’m testing the spray wrap. If anyone has any suggestions, please chime in!
After working on a bunch of displays nothing like putting some awesome graphics from Fammx
S | New wheels Graphics ,Suspension on my Varg. | Stark Varg -- Discussion | 11 | |
F | New Graphics Suspension and Wheels on My Varg | Stark Varg -- Discussion | 10 | |
A | Graphics Kit Templates for Stark Varg | Stark Varg -- Discussion | 4 |
