MXR 2019 won't turn on
Mat Rebeaud
switzerland
I have a new MXR 2019 and 2nd day I ride the bike won't start...
I ride for 10min do a break and the bike never start again. nothing no light no nose nothing...
Do you already hear something like this...
I m in switzerland nobody have alta here no help...
Thanks for you time
best regard
Mat
Thanks for you time
best regard
Mat
What was the state of charge (SOC) of the bike?
When you key 'ON' the bike does the battery LED turn on (blue led)?
Checking the 9V allows us to see whether or not its a BCU problem (within the battery) or a ACM problem. Sometimes the 9V acts up. Hence the post. If the voltage is at 9V on the ACM battery then thats out of the way.
Most likely the BCU board in the battery has failed. There are ways to fix it. But being in Europe makes it more fun.
Could you provide the last three digits in the VIN?
(Also your picture is rotated the wrong way. Dunno if its the bike ahead or behind...looks like you did a battery swap)
There are BCU boards (v2) suitable for the MXR through Ebay. I would purchase one ASAP.
I had the same problem (assuming it is in fact a BCU failure), and it was quite an ordeal.
Luckily, had a lot of help from this forum's experts.
Mat Rebeaud
switzerland
Yes the 9v was fine. And I switch battery from my old bike. And the new bike turn ON fine.
It s a battery problem...
And the bike don’t even have 1hour ride... lucky didn’t cut wen I was jumping...
@Rashid510 what is VIN number
As others have stated you should by a battery BCU off eBay from liquid performance and you will also need new battery contractors from Gigavac as its is too hard o salvage them from your existing battery as they are epoxied in. I have a quote from Gigavac if you end up needing it
