Wnuudiction
- Maui
Key does nothing, I’m gonna try and change the 9 volt and hope for the bestThe bike is completely dead? The water pump works?
Sadly, I’ve been caught up, I have the frame off and will replace the 9 v tomorrow and see if that fixes it. You’d think with our economy imploded in Hawaii and my work cut back 90% I would have finished but now! My real problem is I still have a 2 stroke so my riding needs have still been filled, much to the neighbors irritation.Any update on this?
Really, yeah I was following the Alta video, I’ll try that first, thanks. And yeah that’s as far as I got yesterday, cleaning the bike, strapping it to a skid, removing the skid frame and unplugging the high and low connectors.When you say frame, do you mean skidframe? Accessing the 9V is a pain in the ACM, but it can be done with the battery and skidframe still installed. Just have to unplug the harnesses (LV and HV) and wiggle down the ACM to get to the door.
Back together with new 9 volt battery, still nothing when I turn the key. No display, no water pump, nothing. I disconnected the ignition and sprayed electrical cleaner in the connector, nothing.
Ugh, I gotta find it, I ignorantly thought it was just gonna be fixed, amateur mistake. My bike did flash a code months ago, I can’t remember if it was a 33 or a 36 l, post reading the forum too much after it died I have gotten confused about which it was, anyway, it cleared itself months ago, or was covered by the 9 volt service. Will a multitool work on a dead bike?What was the voltage of the 9V you took out? I know there was chatter about the 9V but which one did you end up using?
BummerUnfortunately MT will not work on a dead bike. Needs power for the can loop to function.
@metallic88 care to share? Might as well pay it to everyone.
Its somewhat understandable/helpful.
The "fix" requires the opening of the top cover. Looking at the humidity sensor and also one of the smaller caps near the HV side. Separator?
G | Charging question-bike won't take a charge | Electric Powertrain | 12 | |
R | Charging Varg EX remotely? Bike stored away from home.. | Stark Varg -- General | 4 | |
S | Should I buy this bike or stay away? | Should I Buy an Alta? | 5 |
