That's what I'm looking for is an adapter to a110v outlet. Am I going to have to become a sparky or is something commercially ie quality available. Hate to burn up a 800$ charger or worse a 13k motorcycle...The fast charger will come with the 240v plug. You would need to make an adapter if you want to plug into 110v though.
Zero didn't get a very good review from cycle news - they typically will just give the marketing reviews that require reading between the lines...I want this so bad, it kills me that when I want to go for a ride there are electric charging stations all over but I am stuck slow charging on 110v. Makes me jealous of the zero guys with their super chargers. Every time I think of it I feel so sad I need to immediately go bust a wheelie to remind myself why I didn’t purchase a zero. Still though...would love one of their supercharger type setups.
I want to make one so I can use the electric car charging stations.
The 110V outlet is simple, the J1772 "car" plug not so much. You will need some electronics to send a specific signal to the EVSE (that's what the charging pedestal is called) to initiate electricity. Unless you have an SM you'll still need the charger to convert the AC from the EVSE into DC for the battery.I want to make one so I can use the electric car charging stations. Like at Whole Paycheck/ Jeff Bezos Foods. And Carnegie has an EV charging station. Car receptical and 110...
With DC charging you don't need a charger on the bike at all. In fact, the bike needs to be wired to allow for the charger to be bypassed when using a DC charger. The problem is that the vehicle needs to be able to tell the charger how much juice to send at what voltage, when to taper the charge, shut off, etc. To do that there are a few different protocols. Tesla has their own. There is also Chademo (used by the Nissan Leaf and a bunch of others) and there're now a DC charging spec from the SAE (part of J1772). The short version is that the vehicle needs to be built to allow for DC charging from the beginning. It's not something you can retrofit.I do have an SM so that would work great for me. I don’t know enough about charging standards, but with the DC chargers, do they reduce what is needed on the bike (size/weight wise)?
