Trialsman
- Pittsburgh
We did a single track ride this weekend with a lot of "nothing but big rocks". On normal terrain I can reach the ground on my EXR comfortably but here, not so much. One of the things I did to my Husaberg 570 was lower the shock and it made a world of difference. Since I am seldom grounding out anyway maybe I might try lowering the rear an inch or so. Should I use the internal spacer method or possibly work with the linkage arms? I have a mill so I can make parts but has anyone already done this? How did it work for you? How much change in the center to center distance translates to how much travel reduction at the rear wheel? Will this method mess up damping, spring rate, or fender clearance?
