Wanted to share my progress on the YZ125 conversion project.
My goals were simple (in no particular order) - 1) Lighter than the Alta by at least 25lbs 2) No thermal limiting issues 3) Minimal change in CG location to retain handling 4) No frame mods, completely reversible conversion 5) Enough energy to last 15min moto at expert level 6) Use commercially available motor, battery cells, controller and BMS 7) Ability to charge immediately after moto at 20amps without inducing thermal issues 8) 40-45 hp and 80ft/lbs.
Here's the result -
Conversion specs
Motor - DHX Hawk 40 72v, watercooled.
Controller - Sevcon Gen4 size 6 72-80v 550amp
Battery Pack - MSC Designed and built all copper bus bar watercooled 72v nominal 3.9kw/hr Sony VTC6
BMS - ANT 450plus amp
Mechanical specs
Roller - 2006 Yamaha YZ125
Forks - Factory "works" all aluminum 52mm WP forks and triples
Shock - WP Trax Shock
Swingarm - Late model KTM and linkage
Wheels - KTM Racing
Brakes - Factory KTM oversized front caliper and twin piston rear caliper with LHRB
Weight - 246lbs
What about my goals? Some items are clear based on testing already completed. 40-45hp is not going to happen....there was a slight misunderstanding in motor specs which makes this impossible with the current battery pack. My inertial chassis dyno says 35 hp and 65ft/lbs is where it's at right now. I'll need to do some side-by-side testing with my Altas for a final judgment. Missed my weight bogie by about 5 lbs, however, no weight savings heroics were attempted. I'm sure 5 lbs could be lost quite easily (but the Alta can do the same thing!!!). The watercooled battery pack is working beyond expectations during use and charging, but it's not summer, so . . . . . . . The size of the motor (very small dia) and battery pack (relatively short) fit between the stock lower rails and secondary head tube support tube quite easily. Only minor penetration into the gas tank area resulted in very little change in CG. The original fwd/aft weight bias was retained. Run time (race time) has yet to be fully tested.
Interesting tid-bits - The original design called for a single water pump and cooling circuit. However, the difference in operating temperatures between the battery pack and the motor/inverter is significate enough to dictate separate systems. Therefore, the bike shown (and weighed) has two electric pumps and individual radiators/plumbing. This obviously adds weight and complexity but I feel it'll be essential in keeping pack temps in check during the hot summer months. Also, the Sevcon size 6 controller is a MASSIVE beast. There are other controllers available that I feel will do the job and are much smaller/lighter (about 5-6 lbs). The issue would then be thermal, as the shear size/weight of the Sevcon helps in this respect. The trade would be the additional weight to watercool the smaller/lighter controller(s). More info TBD as track testing gets underway.
Here's the result -
Conversion specs
Mechanical specs
Wheels - KTM Racing
Weight - 246lbs
