Blatant Moto
- San francisco
This is a collection of prototype body work from the early days of Alta and a couple pieces from Redshift 2.0. Good man/woman cave wall art. All of it is one of a kind. Not really functional bodywork, and I make no guarantee about fitment whatsoever. Shipping is on you and subframes could be expensive. Happy to take more photos.
-all black MX kit. Complete all black subframe with Kris Keefer test pilot graphics. Subframe should bolt on to your Alta but will need sleeves for mounting points. Shrouds are cast urethane and will not bolt directly to your Alta. Some repairs here and there. Front mount is different. $500
-BRD redshift shrouds/front grill/subframe. Numero Uno. None of this will bolt on to your Alta. One of the spears on the front of a shroud is broken. I don’t have the missing piece. $250
-early early MX shroud and number plates. Number plates are simply painted Honda 450 plates. Shroud is cast urethane. $100
-redshift 2.0 MX/EX headlights, front fender, and number plate. All 3d printed from ABS. Headlights and turn signals are DOT and headlight is better than the polisport “stock” light, especially with an LED bulb. Will bolt up to your Alta. Need to run the bash pad on your SM in order for either set to work. $250
-early prototype SM body work. Fender and side number plates should bolt on to your Alta. Shrouds would need modification. One shroud has a broken tab. $350
