- Lake Havasu City, AZ
It might be difficult to wheelie the Alta through the rotating turnstile.Can’t you just drive it into the building and plug it in at your desk or whatever? I have it on good authority that they fit through doors and your neighbors probably won’t even complain about exhaust fumes or noise. People do this with bicycles all the time.
Sounds like a good obstacle for the hard enduro guys, who's up for demonstrating the technique?It might be difficult to wheelie the Alta through the rotating turnstile.
We don’t?Should we just start a sub-forum specifically called “Range Anxiety”?
Is there any level 2 charging around where you work? If so you could build an adaptor pretty easily that would allow you to charge there with the onboard charger. It would also probably be 220Vac so it might charge faster. I don't know anything about the onboard charger for an SM.View attachment 8951
This was my bike today, charging at work for the first time, and possibly last. The general manager of the facility decided to put an end to letting the Zero owner charge his bike. I am not sure what the reason is, but I will try to find out. I had to beg to let me charge my Alta so that I don't have to ride back home in a tow truck again.
Really? Oh! That's good to know! We have three different ChargePoint J1772 6.5 kW charging stations in town, and I also think they are free.Is there any level 2 charging around where you work? If so you could build an adaptor pretty easily that would allow you to charge there with the onboard charger. It would also probably be 220Vac so it might charge faster. I don't know anything about the onboard charger for an SM.
