2018 Redshift MXR a diagnostics
GrahamD
Hi all,
Just received a 2018 MXR and want to do full diagnostics and firmware update if needed.
Also maintenance such as coolant change along with gearbox oil change.
Any tips or links to threads?
Expecting the Varg at Xmas so wound like to get used to electric befits having the Varg.
Congrats on getting an Alta!
You can read about changing the oil here:
And you can do this:
Or maybe this:
Sadly, the loaner kit is no longer available to lend out. It did not survive the last return trip it made in November. RIP loaner kit. 😢 I didn’t send it internationally anyway.
GrahamD
Parts ordered and most have arrived.
Anyone know a compatible rear brake lever/ pedal with better end for grip using enduro boots. The flat pedal is no good for enduro usage.
Go for the left hand rear brake. Your foot will thank you.
