Wnuudiction
- Maui
This is the official info that Alta emailed to me:
This applies to the 2017 MX models. The 2018 MX appears to have all the same components. The SM and MXR models obviously have different springs.
Wheels
· 2014 KTM specs and bolting patterns
· Front will need a 7mm spacer between the disc and the hub
· Outer spacers are to Alta specs
· Warp 9 is our current supplier and is allowed to support aftermarket
Suspensions
· KTM 2014 4CS forks, 0.52 kg/mm spring rate (RaceTech has 0.54 - FRSP 434654; Slavens Racing has 0.55 kg/mm)
· KTM 2014 shock, 6.3 kg/mm spring rate (RaceTech has 6.6 - SRSP 652666 & 6.0 - SRSP 652660)
Controls
· Harnesses allow for 2” handlebar risers
· Levers that fit Brembo masters will fit our bike (2014 KTMs)
Brakes
· Front and rear brakes and brake pads are from 2014 KTMs
Pegs
· 2015 Yamaha YZ250F OEM will fit
Graphics
· Factory Effex has the template and can do custom kits
Sprockets
· 2014 KTM specs front and rear
Handguards
· Universal mounts will work
Bodywork
· Our MX front fender and number plate is from the 2009 CRF450R (we use Acerbis)
So I bought a wheel set on Craigslist off a ktm 500 exc, I wanted to be able to run real road oriented tires on the stock rims and then tubliss and super soft off road tires on the ktm set. Should I just order 7mm individual spacers, or is someone making a plate that goes under the disc.
