Headlights ✔️
PsychoBunny
Southern California
Off to the mountains to test them out. Was going to put them on the handlebars but they fit perfectly on the forks :)
2400 Lumens each, got two for redundancy. Can remove each in 1 second via the rubber strap. Didn’t have the lights aligned for some pictures but you get the idea. Will have to do a video at night so far seems like a winner.
Light picture 1 - 700 lumen each.
Light picture 2 - 1500 lumens each.
Light picture 3 - 2400 lumens each.
eddiebee
Caribbean
I'm working on a minimalist lighting setup to get road legal, to avoid using a trailer as there's a mx track a few miles from my home. Found this DOT/ECE approved lowbeam projector which is only 1100 lumens but has a sharp cutoff.
View attachment 11804View attachment 11805
That looks nice, and definitely passes the “minimalist” test!
I assume you need tail/brake lights as well.
Do they have to be DOT approved?
eddiebee
Caribbean
Not usually, but I suppose it depends where you are. I don't need a highbeam but do need a tail+brake light, signals, and at least one mirror.
Torqu3
MA
I love how compact and minimal it is. I was going to do something similar but really couldn't find a low enough profile light that I liked. I also did not consider having it shine through a window in the number plate, I was going to try and flush mount it. Could you post some beam pattern pics?
I ended up just mounting a pod at the top of the number plate. It's a triple pod dual beam (high/low) unit. It works well but I want to firm it up a bit, more bouncy than I'd like because of mounting.
Front indicators.
eddiebee
Caribbean
The Koso Mini LED headlight series is available in lowbeam, highbeam, or fog. I got the lowbeam version.
Unfortunately the mounting position isn't perfect as the front fender blocks the light hitting directly in front of the bike, but for my needs it's fine.
Bendejo
Rhode Island
How have the Lezyne lights worked out for you? My buddy and I want to go night riding on some trails and I think this is the ticket. Any opinions after some experience with these?
