Foss
Stark SME
- Vestal, NY
Has anyone sourced a flex lever for the left hand brake 10mm brembo? All I can find are clutch levers, Thanks!
This?Good news: There is no such thing as a "left-hand brake Brembo". They are all clutch master cylinders.
Hmm... Maybe it is from the KTM Freeride E. I stand corrected!This?
SMX1-BR-RWHB-02
Rear hand brake master cylinder (Brembo)
This is the 10mm LHB, and just to note, I have this setup with the dual peddle and hand brake Rekluse and works great. I got rid of the lame 9mm Formula and balanced it with two brembo 10mm.
The brembo 10mm master cylinder SUCKS compared to the 9mm. The 10mm doesn't have the stopping power and instant lockup that the 9mm has. I'm taking the 10mm off my brand new Stark and putting a 9mm Brembo master on there with a new hydraulic line made by Spiegler.This?
SMX1-BR-RWHB-02
What's is wrong with the Formula master cylinder?I got rid of the lame 9mm Formula and balanced it with two brembo 10mm.
I have always been having the Formula master cylinder, installed inward on the handlebar and used only with my index finger, pulling the lever at about 3/4 of its lenght.What's is wrong with the Formula master cylinder?
I'd like to know before I spend too much time/money/effort adding a wrong LHRB lever.
Can you tell me where you found a 9mm Brembo master cylinder? I'd like to find either a 9mm or 9.5mm and would prefer a brake mc rather than use a clutch mc.The brembo 10mm master cylinder SUCKS compared to the 9mm. The 10mm doesn't have the stopping power and instant lockup that the 9mm has. I'm taking the 10mm off my brand new Stark and putting a 9mm Brembo master on there with a new hydraulic line made by Spiegler.
Thanks, can you tell me what size bore is the master cyl you bought? It may be marked on the underside of the reservoir.Here are a couple options. I purchased the new one from Lithium and it's perfect. Now I just need to get it mounted up. I'm doing the conversion to the rear master to keep both foot and hand brakes active. I also purchased the long line that's supposed to go to the rear caliper, but I'll just loop it somewhere behind the plastic to keep it short.
Brembo Rear Brake Caliper / Hose / Left Side Lever Master Pump | Front | Black | Aftermarket | Rust-Resistant | Brake Line
Find many great new & used options and get the best deals for Brembo Rear Brake Caliper / Hose / Left Side Lever Master Pump at the best online prices at eBay! Free shipping for many products!www.ebay.com
I'd like to have that Rekluse. I have one already and I'm not sure it works all that well. I'll send a PM.I also have these I don't need if anyone want's them? I'd sell the Formula master for $125 shipped US and the Rekluse for just the cost of shipping as I'm not sure it's fully functional. I got it from Rekluse locally as a test kit.
Hey, does the Brembo pic I posted above look the same as yours? I'm unsure how to tell the bore mm of mine, which sounds like an important point for these rear brakes.I have a Stark left hand rear brake lever (9mm) and brake line for sale if anyone is interested - they are brand new
I'm interested, I need to know which master cylinder you have, photos would suffice, and the price. Is 9mm marked on the master cyl or how did you determine the bore size?I have a Stark left hand rear brake lever (9mm) and brake line for sale if anyone is interested - they are brand new.
