Yamaha 2000w generator/inverter
NorCal_Hoss
Norcal foothills
I have been riding my stark around my single track on my property, planning on riding a few tracks and know my buddies are going to want to try it out. I have a honda 7000w inverter, it is a big generator that I can't lift and put in my truck, I do have a yamaha 2000w generator/inverter, the bike is fully charged right now so can't test it to see if it works or not, can anyone confirm this small generator will work? The few times I rode it and had to charge it, I used my 110 in the garage and tripped the breaker a few times but it did end up charging, it took like 4-5 hours and the charging stand was very hot. At home, I will charge with the honda 7000w but just wondering if the smaller 2000w yamaha will charge the bike at the track.
Thank you
Put the Stark in under 2000W charging and it will work.
I have a 4000W generator and sometimes i have to use other power consumers parallel to the Stark. Then i just optimise the Stark. Generator power - other load - 200W safety = charging mode on the Stark.
So in your situation i would charge the Stark at 1800W.
You can only charge from 110V from this Yamaha 2000 generator, so it will be slower. Yes, it will take about 5 hours from empty. If you are not in a hurry then it will work just fine.
Put the charger on the max charging current, and it will still be around 1700W, not 2000W+. It should be okay.
NorCal_Hoss
Norcal foothills
Philip,
When you say put the "charger" on max current, is that within the phone? I think mine says 6 amp right now. Put the highest charging current for the 2000w yamaha?
What amp should I have it on when charging in my garage with 110? And if I bring the honda 7000w out, would I change it again ? Sorry bud I don't know much about this stuff :)
Philip,
Yes, your phone tells the Varg charger what current to send to the bike. Just keep it on the highest setting, unless you start stalling generators or popping circuit breakers.
Regular US household outlets are designed for 15A x 110V = 1,650 W. The Varg charger should not be consuming any more than that in the 110V mode. Maybe my 1,700W number was an overestimation, I went by memory. Either way, this is still way below 2,000 W nominal rating for that Yamaha generator. The continuous rating may be lower, but this is a Yamaha, I think it will keep up.
Thank you
Your household 120v circuit could have been tripping because there were other loads on the same circuit at the same time. To avoid that, you could do several things: Remove all other loads on the same circuit. Use a different circuit with no other loads. Lower the charge rate (which lowers the load), but I'm guessing the issue was other loads as the max charge rate on a Varg on 120v shouldn't trip a 15amp circuit with no other loads.
Note that US standards are 120v and 240v (though may still use the outdated 110v and 220v). Use 120v and 240v for your calculations. If you put a multimeter on your household NEMA5-15 outlet (your regular old household outlet), your going to see 119v - 120v (not 110v).
Per electrical codes and industry standards for household circuits, best practice is to to limit your load to 80% of circuit rating. 15amp. 120v x 15A = 1,800watt. Times .8 leaves a sustained load capability of 1,440watts. It's my understanding the Varg uses a 3,300W(3.3kW) charger, but you only get that on 240v. Using 120v limits you to half that rate, so 1,650W. There are many that would go ahead and charge at that 1,650W rate on an 1,800W household circuit. Up to the user. You'll be pulling about 14amps through that 15amp 120v circuit.
If you have a 240v circuit (or generator), you can charge at the full 3.3kW rating. Note that it will draw about the same 14 amps, but because it's 240v rather than 120v, the load will be twice the 1,650watts, so you'll get the full 3,300watts. That is all based on the charger capability and, as some have said, there were/are some software/apps limits, but I don't know if those have bene updated. Also, the above calculations are based on zero losses. There are efficiency losses with all chargers, so your output, in watts, to the bike will always be less than the watts consumed by the charger.
As others have said, using a 120v generator works fine and you simply set the Varg charge rate low enough to compensate for the sustained capacity of the generator. On 120v, even at max charge rate, it is fairly low (the 1,650watts estimated above). Like most generators, the Yamaha 2000 naming convention is misleading as that "2000" in the name is the max "start up" or "surge" wattage; not the max sustained load (or "rated load" or "running load"). The rated load on the Yamaha 2000 is only 1,600watts. You don't want to be right up on the max of rated load rating as it may trip when you are away or not paying attention and then an hour goes by with no charging. Set the charger to draw slightly lower than your generators 1,600watts load rating.
As for different voltages, amps and watts. V x A = W. So if you know two of those parameters, you can calculate the third. Since your generator can carry a sustained load of 1,600watts, that is 1,600 / 120v = 13.33amps. Set your Varg charger to pull 13.33amps or less (1,600watts or less) and charge away. It will be a slow charge, but slow is better than nothing. Not counting efficiency losses which are usually 5 to 10%, The Varg battery is 6.6kWh. If you set charge rate to about 1,500watts, it will take about 4.4 hours from 0% to 100%. If 10% losses, figure about 5 hours to charge. That means you'll see your battery gain about 20% charge per hour at 1,500watts input.
NorCal_Hoss
Norcal foothills
Thank you for taking the time to write all that information. It is very helpful.
