Sold 2018 Alta MXR "'murica Edition" Florida
reeldealev
Tampa
$6k Tampa, Florida
2018 Alta MXR
2115 Miles
214 Hours
I love riding this, but after a recent ride I forgot to unplug it and it charged to 100%. The battery control module needs a reset because if it charges to 100% it will not work until the battery drops to 98%, the fix I have been running for months is not charge to 100%, but I got distracted... I went to purchase the Can Bus adapter I need to hook it up to Alta Multi-Tool and was shocked to learn the stupid piece cost $300! So I decided I would take some lose and sell it as is. I am draining the battery now, so it will be fine when you buy!
Comes with a Factory ALTA charger. Nihilo Titanium Foot Pegs. Seat Concepts Seat, ProTaper Handlebars, Tubeless Traction Control System. I do have the OneLapper's Data Port Cable that I will provide to the buyer as well.
slowjet
Ma
Canbus tool is $75. Just ordered one from the forum here. How are you running the battery down?
reeldealev
Tampa
All the links I tried were broken, so I just googled them and they were around $300..I just push the button to turn the coolant pump on. (oh I should add that to the description, it has a push button instead of the key)
slowjet
Ma
That's a good idea I need to run my battery down a bit.
My Redshift EX also needs some discharging from 100% in order to work.
I never let it charge to full.
I connect it to mulritool, so the bike stays on longer. Otherwise it has an auto shutdown after about 15 minutes.
bluefxstc
Boise, ID, United States
What is the issue with charging to 100%? I have never had a problem charging my EX to 100%, but I do have a very early version of the software, so that may keep the bike from having issues.
It could be related to out of date BRD boards (these.are the small electronic boards attached to each battery module).
They were recalled, but not all bikes were updated before Alta closed down.
reeldealev
Tampa
I did install a new BRD about 6 months ago, I am not sure what the date of the board was though..
