I would like to change the brake caliper adapter, but I don't know how to remove it
D davos2410 Member Likes 6 Location España May 29, 2025 #1 I would like to change the brake caliper adapter, but I don't know how to remove it
W WoodsWeapon Well-known member Likes 251 Location USA May 29, 2025 #2 It just slides off. It’s currently held in place from the friction of the rubber boots seated in grooves.
Philip Administrator Staff member Likes 4,448 Location Lake Havasu City, AZ May 29, 2025 #3 You need to use an 11mm wrench to unscrew the pin that your photo shows at the bottom.
D davos2410 Member Likes 6 Location España May 31, 2025 #4 WoodsWeapon said: It just slides off. It’s currently held in place from the friction of the rubber boots seated in grooves. Click to expand... And how can I leave it? Because pulling it with my hand doesn't come out.
E Erwin P Well-known member Likes 377 Location Netherlands May 31, 2025 #5 Once the Brake pads and Brake pads holder pin are out it should slide right off.
D davos2410 Member Likes 6 Location España Jun 1, 2025 #6 Erwin P said: Once the Brake pads and Brake pads holder pin are out it should slide right off. Click to expand... Okay, thanks for your help. I also had to remove the brake pads.
