Stark Varg: Gearing for optimal range
Now you are getting what I was saying. With a gas bike like my Beta 480, the rideability goes up with taller gearing. Less wheelspin and clutch and shifting, just cruise and it's got so much torque and flywheel stalling isn't an issue. The optimum spot for me is 15/48 which for most is considered street gearing (I go to 45 on the street). This won't work with a smaller bike with less torque, you need massive torque to pull it off, exactly what the Stark has in spades. The Stark has more torque at the first crack of the rpms than the YZ450 has at any point in any gear. It can absolutely pull the tall gearing, and tuning with the tallest gear the bike can pull has always been my go to.
I'm actually a guy who likes shorter gearing on most of my bikes. That way it's more predictable over most objects and really doesn't stall or lacks power to do something when i want it. I normally ride 2 strokes though and somehow when riding the EXC500/TE501 etc i always stall them everywhere. I really don't like those big 4 strokes. Never ridden the 480 though and maybe that's less keen to stall.
Back to the Stark. Indeed that can't even stall and torque is endless. However HP is not. HP basicly is Torque x RPM. With very low revs i've found that the Stark actually has a bad time in really deep mud. In 48hp it won't spin itself out of it when stalled. Even 80hp has to work hard. An ICE can drop the clutch and release top hp at 0 km/h, the Stark has to make due with a huge torque number x 0, and a funny thing happens when you multiply by zero.
However, that is something i would need to test, hp should be plenty though.
markhamr
blaxlands creek australia
I have trouble with range a lot.
Looking at peoples data and videos I can see why.
My best 58 minutes 63%
I was riding slow doing some track maintenance.
I have averaged 48 kph a hour with a top speed of 131.9 on this track.
about 1klm of that and a lot of pulls to around 85kph
Some single track / rough logging roads./water bars galore usual rutty woods.
I think 35 minutes is a pretty accurate estimation of true range with the bike pinned.
My worst came back as 32 mins dte 100 to 0
Outdoor mx
My bike has the 13 tooth front sprocket.
Set on 60hp.30 regain
I try to carry the front a lot to improve speed (unweight it)
flameout is a problem on modern enduro 4 strokes(electric start)
I have found deep mud and deep ruts are hard to master on the stark as well.
Stuck in the mud it cannot push the front easily from a stand(it has reverse though)
At those speeds i would say a bigger sprocket up front might would be beneficial.
I do a lott of mud and rut riding and actually find it easy'er on the Stark than on my 300. Might be a personal thing though.
Austin TX
Today was my first time to use my new gearing on the Stark. 14/42 for a 3.0 gear ratio, it required removing 2 links from the chain (112), I chose to run the axle as far back as possible. The steel sprocket was a JT from Amazon for $27. Amazon.com: JT Sprockets JTR460.42 42T Steel Rear Sprocket , black, Medium : Automotive
Super happy with this choice. Surprised 😳 that it was even more responsive off the bottom, in a good way. Hit the apex and dial in a turn wheelie and carry it as far as traction and nerve allows. Stronger acceleration for longer. An increased rideability, but accelerating does come faster.
Used 49% of the battery, 22 miles. Trail pace with some fast pace mixed in. This seems like it’s a better range.IMG_4228.jpeg
Austin TX
Used 49% of the battery, 22 miles. Trail pace with some fast pace mixed in. This seems like it’s a better range.View attachment 14120
markhamr
I have always run shorter gearing on my( stink engine ) bikes. (yachting term )
But a lot of that was because they came over geared to pass the noise level test.
Smoother is always faster and modifying my technique should eliminate
a lot. I will trying gearing it up.
I do tend to drive a bike off the clutch in deep ruts.
The suspension is starting to feel better no mods just me thinking
and i am getting used to flying it more now.
I cant imagine i am ever going to get over the weight thing
13 pounds/ for want of a nail.
Same for me, i love 1 or 2 tooth less up front on ICE's.
Smoother sure is always faster. That's why we saw a big update a few months into 2024. They actually reduces throttle response. That way people actually became faster and somehow real world testing (by me and local riders) pointed out around 10% more range.
Quite interesting how much difference that softwaretuning can do.
The suspension is really different than WP's that i think you're used to. I come from Beta's wich run KYB's or Sachs. With my small YT channel and having a bike (Stark) that people love to try i get the chance to ride a lott of different bikes. I'm not a pro of any kind, but i think i could blindfolded pick out the WP's from the rest.
I don't think between KYB or WP one is @#$% compared to the other. They are just very different and give a very different feel.
Generally people comming of a Yamaha YZ have a very easy time getting used to the Stark and i think those are more like the Stark than any other bike.
Austin TX
To further expand on this topic, I will have a party if I am ever able to drain my battery in 1 ride 😀
I have never used beyond 70% in a day, including rest periods since my arms give up way before the battery does.
By going with 14/42 my goal was improving rideability, and it has been achieved. It’s much less likely to spin and wheelie, easier to keep the front end down and it has a longer peak torque pull. Smoother and faster and less explosive and tiring. The bike has twice the torque of any gas bike like a Maico or CR500 and can easily handle more gearing.
Having shorter gearing on a Stark is pointless, it’s like 4x4 in low on the transfer case, you could tow a house behind it or smoke the tires, but you aren’t getting anywhere fast.
I don’t get many likes on this subject, and it appears almost everyone thinks I’m crazy 😜
Jett is always a gear higher than most, Tomac is a gear taller but max revs and clutching, and they say Prado likes to be 2 gears taller.
But those guys can actually ride really really really fast.
OEM's arn't stupid. So i always try to figure out why they did something before i change it. Too tall gearing on an ICE is often to meet regulations.
But why would Stark gear too short?
Austin TX
I can’t answer for them, but I got my answer for a $27 sprocket. Never going back. Maybe guys in mountains won’t like/try it, but in flat TX it’s great.
I have those front sprockets in numbers from 12-15 since our Beta's use the same and we play with that a lott more.
I think i will go up at least 1 or 2 for SM since it flattens out before the end of the straight.
Austin TX
It didn't look to me like the 15 would fit? I was finding that at the end of the "3rd gear" speed and range the Stark started to run out of steam, not anymore.
markhamr
I do not have a problem with the suspension itself WP SHOWA KYB
I ride on most brands
Is so obvious what the problem is (WEIGHT)
I will try a 14 front currently 13 I ride on steep but i do not think wheelspeed
will be any issue and should benefit only
Will i need a new chain with a dunlop i would say so.
Enough reporting the 450 is on the stand and the suns shining so
time to go do the bit we all love about riding bikes.
HAMR DOWN
Austin TX
I was so pleased with the taller gearing that I got a 15t from Amazon, another $20. I want to find the limits of this massive torque. I will mention that the throttle sensitivity seems to have gone up a bit, things are happening faster when you twist your wrist. Hopefully a test soon, I am in central Texas and those floods on the news got our track too.
