Stark Varg EX - Physical key
notna
California
Is the physical EX key supposed to lock the bike? How do you use it? I tried turning, leaving it in with no effect whatsoever
Jake
Washington State
Turn the handlebars all the way to the left, insert the key and you should be able to lock it. You may have to jiggle the handlebars back and forth a little. There is a slot in the triple clamp that the lock will engage
notna
California
Where did you learn about it? Stark’s support?
If you're new to this:
don't rely too much on direction lock, it can usually be broken by hand.
Or just slide a skateboard under the front wheel and put the bike in a van in under 30 s.
If the bike is gonna spend more than 5 min outside unattended, better attach it to a fixed point with a chain lock.
These are the rules of the game.
