Front rear tire choice
Osika
When stock one go thinking front dunlap 34 and rear battlecross 40. Mostly a flat track a few rocky sections.
Artrax Tire Combo With TubesI ran the Artrax with the combo price deal and they were as good as any tire I've tried for half the price also.
I like a fatter front for comfort and they offer a 90/100, 3 different tread patterns.
What is lowest font stock tire pressure you would run in soft dry dirt? Have heavy duty tubes
I have run 10-11, but I have a flat right now with standard tubes, don't know the reason. I rode it for quite a while before I realized it was flat in the pits. The sidewalls are weak, and if you are big on stopping tire roll on the rim you'll need 13+.
10 is fine as long as they're heavy duty tube's and the ground is actually soft, meaning no rocks or roots, because the terrain will move a bit and absorb impacts too. If there's anything hard in the ground, I wouldn't go below 11 or 12.
Another option is a very soft mousse. Then flats are impossible
Thanks! Stark is a bit heavy, 12 psi ok?
