Has anyone looked into aftermarket chargers?
AbnormalWrench
Seattle, WA, USA
While I was waiting for my EX, I saw the fast charger was $600, which I was impressed, that was a pretty good price. I bought an aftermarket 3.3KW charger for my Zero a year ago, custom connectors and what not for $550. But now they want $1100 for the same EX charger. I'm assuming that is related to the tariffs (I'm in the US)
I was curious if anyone has looked into aftermarket fast chargers? Yes, I know the tariff will be an issue either way, but it seemed a bit over the top.
And I would still love to have a 120v, 800w option that is smaller, lighter, cheaper. I'd buy 2 of those if they were reasonable.
Hola!
I took a look at the OEM supplier of the charger. They say, their gadget, same type and config, will work perfectly with the bike.
They didn't do any changes on their product for STARK.
The point is the CAN communication, and the electrical capabilities. Bike and charger exchange some information periodically. A dataset about every second.
During the winter in Austria, my plan is to reverseengineer the charge- protocol.
Than choose a smaller charger and put an arduino as interpreter in the middle to keep charger and bike happy.
But now it's summer - no time for bits and bytes.
Bernardo
Aftermarket chargers may open a couple of options beyond the stock charger -
  • smaller (and slower), so it can be mounted on the bike
  • water cooled, so it may take up less space if mounted close to the stock radiator
  • faster (>6kW or >10kW) for >1 phase, 16A or 32A outlets
The later batteries have 7.2 kWh; charging with ~6kW should be less than 1C so not maxing out the cells. Will there be other limitations on the Varg?
Molicel P45B used in MX1.0 are rated for 3 C.
If the cells in EX/MX1.2 are similar to Molicel P50B they could be rated for 5 C.
yes, but even if you figure out software part then you have to look/check HARDWARE like charging port/socket + wire gauge + wiring inside battery to BMS, and maybe even BMS itself if it can handle more current
One way to access Bat+ and Bat- is to use automotive HV wire lugs in the controller for a fixed on-board installation or a second charging port
yes, thats also the way, but then you bypassing safety features on inverter/controller, definanetly it is something for ppl who knows how they are doing
