HVR MX2 and HVR 85Pro
Available now!
HVR 85Pro – 6,990€ HVR MX2 – 8,890€ incl. 19% VAT & 1-year warranty on the entire drive train.
You're kidding, right? If this bike had been out when I bought my Varg, I probably wouldn't be on this forum right now.... Regardless, for that price, either do your own conversion (which is basically what this bike is), or just buy a Stark. Happy to see other companies trying, but today you either have to come in with something completely different or straight up more affordable in order to set yourself apart.
Agreed on the full size bike.They're just using a standard QS138 70H V3 with their own fluid for cooling. Nothing unique there. However the frame does not look familiar, so that might be something proprietary. Regardless, for that price, either do your own conversion (which is basically what this bike is), or just buy a Stark. Happy to see other companies trying, but today you either have to come in with something completely different or straight up more affordable in order to set yourself apart.
Also the low voltage battery will run quite high currentes to get 41HP, overheating will probably be an issue.
The Fast Ace suspension is not for jumping, though.
You are asking for quite some trust here. Can you please explain why you think that? Do you feel like commenting something about the frame and swingarm, too?That suspension will not break on impact, i'm quite sure of that.
Press release tests and lot of videos in which people rode it hard successfully, back then, was way better than the unknown to me.To be fair, we didn't know about Stark either. The one thing that had going for it was a way bigger press release and more money behind it.
I thik it's the right explanation. I know for working reasons that, at least here in Italy, it would cost some thousands € to make a pattern to be used for sand moulds, for example, for a component like a triple clamp. Then usuallly each cast triple clamp has a cost that depends on the batch size and then some machining is still needed.As for CNC vs Cast... CNC is comparetifly cheap on small scale while cast only gets cheaper with bigger numbers. So it's quite logical what we are seeing.
I really hope that Stark will repair batteries like this!3. 2025 The battery had a faulty cell. I send the diagnose data via the app to HVR (Yes... this works also there!) and they confirmed a broken cell. They repaired my battery for 110€! within two weeks.
I am still extrem happy with the great support (even during events at the weekend i got instant response for a charger question). Also for bikes far out of warranty they are doing a great job.
For the simple fact i've been riding for quite some time and have been bashing mopeds in 3-8 hours MX competitions, did abuse Chinese dirtbikes etc etc. Never have i seen suspension fail on impact (other than the brick cheap €500 pitbikes). I still have my moped wich was insanely abused for MX between my rides to school. That thing has 36mm forks (if i recal correctly) and a simple shock. If that lands on flat table tops from multiple meters this will be fine as well. I think the damping and such will be more of an issue compared to a KYB 48mm. But those limits are probably found well before the breaking point.You are asking for quite some trust here. Can you please explain why you think that? Do you feel like commenting something about the frame and swingarm, too?
Here is an interview, released some months ago, in which Wass mentions tests like 50G landings: from 1:09:27:
So yes, what you say makes sense: they advertise CNC milled clamps to be something premium and it probably is indeed I suppose, and like you say, it's also cheaper for them.
