Lights on EX
Spam Assassin
I just bought a new EX and have 2 questions:
I just connected the rear fender and blinkers, but now my centre tail light won't turn on, is that normal? Also the light doesn't react to the brakes, don't know if it did before though.
Also when i turn it off the indicator light often turns white. Anyone knows what that means?
The center tail light does not work when the rear indicators are connected. I think you may have mixed up or not connected the brake switches correctly at the front connection block. It also be the reason for the light blinking white.
just remove those lights before they break off anyway. the integrated tail light has brake lights and turn signals. attach your plate (+plateholder) directly to the 3 holes under the tail light.
I see the problem now Erwin, you only have 6 bikes in that first picture. Unless there is another hiding outside of the frame, you need a 7th so you have one for every day of the week.
@Karinshi Thanks, that's where i bought them for 😜
@DaveAusNor Your eyesight needs some work. There are 7 in this picture, but luckely you're right, there is 1 more hiding outside the picture.
Thanks for the asking Sam, the red button does indeed stick.
As for the whoite light.
Contacted Stark 10:05 this morning. They replied with a question, send them answer and a picture. Now at 13:32 i have confirmation they send me a new handlebar switch.
I always found their tech support quite good. Now they seem to have added speed to the list (y)
