Left Hand Rear Brake ( + keep the foot brake)
TheLHRBguy
Salt Lake City, UT
Hey guys,
We are releasing our Brembo Racing left hand rear brake, that retains the full function of the factory foot brake… The best of both worlds!!
Our system will come pre-bled, and installs in under 15 minutes. It simply replaces your factory pushrod, with our patented Hydra-Cylinder. NO mixing or fluids, and NO Bleeding whatsoever.
We’ve been testing this for the past year, and ready to release to you guys.
Feel free to call or text with any questions.
801-455-8488
(System pictured is a “test unit” and marked as “mineral.” All Stark units are DOT, and will be marked accordingly).
Www.oxbrake.com
fred900
Sun City Ca.
That's pretty cool, way to think outside of the box!!! If I didn't already have a duel setup working, I be like take my money!!!!
So, if I have understood how this works:
• you need the foot operated setup to use it, so you can't add a foot brake to a hand brake setup
• when you move the hand lever alone, the foot lever will move, too without the foot pressing it
• when you move the foot lever alone, the hand lever will feel soft for the first part of its stroke because it's not pushing anything
HadesOmega
San Jose
You are correct except for the last one sort of. If you do thevopposite of what you said give it handbrake then footbrake it will stiffen the brake up a lot. It will lock the wheel up fast.
The footbrake will move a little when given handbrake.
I have the OX brake for the Redshift.
Swank171
Hey guys,
801-455-8488
Www.oxbrake.com
I actually was calling and e mailing you guys a month or 2 back. Left a message and sent multiple e mails.
Never head back. If I knew I would have waited. Ended up doing this setup.
The OEM front brake line for the stark was the exact length for this setup.
