Advanced Mode Power
DirtSurfer
Portland, OR
I'm starting to play around with the power modes (and regen) on my EX.
1. I'm struggling to find any actual documentation on how to do it
2. I don't see the ability to adjust flywheel weight (is this a future capability?)
3. it would be awesome to have 2 settings, 1 that mimics a 300 two stroke 2 that mimics a 450 four stroke.. welcome ideas there
Also, pro tip, if you need to pick your bike up, like on the side of a cliff, PUT IT IN REVERSE CRAWL MODE FIRST - or just ensure it's in Neutral! (Otherwise you risk whiskey throttling it when you yank on the bars to lift the front wheel up, potentially launching it off said cliff....)
FreddyFugazi
BVT
- Click modes > advanced modes > Select a mode to customize it.
- The power curve has a bunch of dots on it, press and drag to move them where you want them.
- The lighting bolt icon switches between the power and regen maps for the mode you have selected
- Hit the save icon to save your changes (I forgot this several times)
I started a discussion thread about getting the most out of advanced modes over here that might have more useful info for ya
Advanced Modes: What Are You Cooking Up?
Good tip btw. Sounds like youre speaking from experience haha
AbnormalWrench
Seattle, WA, USA
I literally did this a month ago. Had a tree down on a single track trail that was a cliff on one side. It was a weird angle and I got the front wheel over the tree and was trying to swing the rear wheel over, gave it a little throttle on the way down and watched it launch off the cliff. Took about an hour to get it back up top. I usually ride by myself but I carry a ratchet strap with me, that has come in very handy a few times.
