John Lindemann
- Clarksville IN
My Stark Varg MX1 will not switch to Run mode.
I can select, Run/off(flashing green), standby (flashing red), charge (solid blue, charges fine) and Off (no lights).
I cannot switch to Run, walk forward or walk reverse. I have a spare switch and I’ve swapped out the switch and that didn’t solve the problem also the things I can select with the switch indicate that all 3 switch elements are working.
Once again the bike was working just fine until I carefully hosed the mud off with a garden hose. I then rode it onto my trailer and it took several attempts with the switch to get the bike into standby. The bike now refuses to switch to run/on (solid green) light.
Any help is greatly appreciated
