STARK FUTURE UNVEILS THE STARK VARG SM: Supermoto like NONE Other
Chief Happiness Officer
Stark Future
Barcelona, October 14th, 2025
Stark Future proudly unveils the VARG SM, the world’s most advanced electric Supermoto.
Building on the global success of the MX and EX platforms, the VARG SM brings Stark’s winning DNA to the street, redefining performance, design, and sustainability for a new generation of riders.
At just 124.5 kg (274.5 lbs) and producing up to 80 hp, the VARG SM offers the highest power-to-weight ratio of any production Supermoto. With 914 Nm of torque at the rear wheel, acceleration is instant, predictable, and endlessly controllable.
Riders can personalize power delivery, engine-braking, and regeneration to match any surface, from tight city streets to technical kart circuits.
ADVANCED BATTERY AND POWERTRAIN​
The 7.2 kWh honeycomb magnesium battery doubles as a structural component, enhancing chassis rigidity and overall balance. It delivers solid performance across various riding conditions: up to 120 km (74.6 miles) in mixed-urban settings, 79 km (49 miles) on highways, and 81 km (50.3 miles) under WMTC real-world testing. Recharging takes less than two hours using Stark’s revolutionary 3.3 kW portable charger, compact enough to fit in a backpack and compatible with standard household outlets or AC car chargers.
The carbon-fiber-sleeved motor with integrated inverter sets a new benchmark in power-to-weight efficiency. Tested against the brutal demands of motocross, it's built to take on a challenge, validated to full automotive standards.​
PRECISION ENGINEERING AND CONTROL​
The VARG SM is built on a high-strength steel frame with a forged aluminum subframe and precision-machined triple clamps engineered for ideal stiffness and flex. Suspension is provided by KYB, featuring fully adjustable 48 mm closed-cartridge, 290mm stroke forks and a triple-adjuster rear shock with 303 mm of travel.
A newly developed triple clamp gives the SM greater steering precision and front-end feel, while CNC-machined hubs, aero-grade rims, and Brembo brakes deliver exceptional stopping power and stability.
The cockpit features internally routed wiring, a CNC aluminum map switch, and Stark's rugged Arkenstone display, a waterproof, shock-resistant Android-based dashboard providing GPS navigation, real-time ride data, over-the-air updates, and full tuning control directly from the handlebars.​
CONNECTIVITY AND CONTROL​
The cleanest cockpit Stark has ever built: internally routed wiring, CNC aluminum map switch, and a rugged Android-based Arkenstone display. Waterproof, shock-resistant, and fully connected, it delivers GPS navigation, power tuning, OTA updates, and ride data at your fingertips. Riders can switch between modes instantly, commuter, stunt, or track weapon — with customizable power curves and braking profiles.
REVOLUTIONARY ROAD-LEGAL DESIGN. EVERYDAY PRACTICALITY. EXTRAORDINARY DETAIL.​
The Stark VARG SM isn’t just built for performance; it’s built for access. Fully road-legal across Europe, Australia, New Zealand, and parts of the United States, it allows riders to take race-level electric performance to the streets. With A1-license compatibility and even car-license eligibility in select Southern European countries, the VARG SM opens the door to a new generation of urban riders, making high-performance riding more accessible than ever.
Whether commuting, connecting trails, or carving mountain passes, the VARG SM redefines convenience, control, and confidence.
It’s equipped with intelligent, rider-focused innovations including Crawl Mode for reversing in tight spaces, customizable ride modes, digital security layers, and an optional handlebar-mounted handbrake for perfect control in stunt or track environments.
Key road-ready features include:
• Patent-pending flexible indicators, crafted from durable optical silicone for superior longevity.
 • A 4,000-lumen headlamp — three times brighter than any competitor, ensuring exceptional visibility at night.
 • A reinforced, integrated license-plate holder combining minimalist design with robust protection.
Every line of the VARG SM reflects Stark’s design DNA, muscle, tension, and flow, sculpted by function, inspired by nature, and engineered for precision. And with no pistons, filters, or valve adjustments, maintenance is minimal, saving riders time, cost, and complexity.​
PERFORMANCE WITH PURPOSE​
The VARG SM is built to strict European environmental standards, utilizing sustainable materials and processes. It produces zero emissions while outperforming every combustion Supermoto in its class. Because performance without responsibility is just noise.
The VARG SM offers an unprecedented level of customization, including:
 - Titanium upgrades for footpegs, bolts, and shafts to further reduce weight.
 - A choice of four different tubeless tire options.
 - Foot or hand rear-brake options (handlebar fitment included free for U.S. customers).
Motor typeElectric PMAC
Gears1 Speed
Weight124,5 kg (274,5lbs)*
Maximum power80 hp
Battery capacity7.2 kWh Honeycomb magnesium
Torque914 nm
Range81km(50.3miles) - WMTC**
120km (74.6miles) - mixed urban
79km (49miles) - Highway
Charging time1-2 hours (240V outlet)
Front brakes4 Piston monoblock radial caliper with 320 mm floating disc
Rear brakes220 mm hydraulic disc Brembo
Front suspension 16mm offset, 205mm between fork tubes: Machined Triple Clamp, Kayaba SM Specific with Fully adjustable 48 mm closed-cartridge, 290mm stroke forks.
Rear suspensionRear shock: triple-adjuster 303 mm travel
FrameHigh-strength steel
Tires 4 options available for Tailored preferences.
o Pirelli Diablo Rosso IV (Default)
o Dunlop Sportsmart TT (Performance)
o Michelin Road 6 (Wet and cold weather)
o Anlas Grip Plus (Extreme wet and cold weather)
Lighting Powerful headlamp with patent-pending integrated indicators with over-molded optical silicon. License plate holder molded into the rear fender with integrated indicators.
Walk mode + ReverseWalking/ crawl mode and reverse gear.
* Race Spec (excluding homologation kit, mirrors, plate holder…)
**WMTC: World Motorcycling Test Cycle
*** Limited availability Worldwide
The Stark VARG SM is available to order immediately through Stark’s global dealer network of 500+ or through StarkFuture.com.
Now Available Worldwide: PRICING: EU, UK, US, AUS, NZD
Pricing:
The bike will be available in two configurations:
 • Standard (60hp): €12,990 / GBP 10,900 / USD 12,900 / CAD 17,990
 • Alpha (80hp): €13,990 / GBP 11,900 / USD 13,900 / CAD 18,990
Australia
 • Standard (60hp): AUD $21,990 + $1,600 ride-away contingency
 • Alpha (80hp): AUD $22,990 + $1,600 ride-away contingency
New Zealand
 • Standard (60hp): NZD $23,990 + $1,600 ride-away contingency
 • Alpha (80hp): NZD $24,990 + $1,600 ride-away contingency​
The discussion is here:
Besides the supermoto wheels and a big Brembo front brake, the biggest news is the new portable mobile charger.
