- Austin TX
As long as you have good throttle control, the first 1/8-1/4 of the throttle is the same torque regardless of setting IMO? You don't get the big ponies until you twist it really good.The crack of the throttle between 20 or 60 is worlds apart though...?
Wheelies kinda, but i roll on smooth on the straight an thus it is no issue. Same in the corners. Smooth opening gives a super predictable response, way smoother than any ICE.
Offcourse full power and open throttle gives both wheely and wheelspin at the same time. But since i'm not suicidal i put it in 48hp and have grip instead.
