I got mine set up over the weekend but I need some things clarified please. I tried mounting a 15 tooth counter shaft sprocket but it wouldn't clear the swing arm buffer. It rubs where the buffer wraps around the front of the swing arm. Do I have to remove some of the buffer?
The front brake caliper relocating bracket rubbed on the thicker (4MM) rotor. I had to file some material off of it and shim it off of the rotor. Is this normal for all relocating brackets? Or is it because I bought a cheap one off Ebay? Thanks in advance.
