Stark Varg sidestand bracket
Coverage may be an issue when falling on the side and some pointy rock sticks out. Has been with a few riders (broken of cooling fins). The question there is how far do you want to go and with what compromises? More coverage is less air and obstruction to where you can put your boots. But too little might be a damaged battery.
Also the linkage might be well served by a extender that covers it. But that can be done with a modifaction to the OEM plate that would/should not void the warranty since there is no extra force in the mounting points on the battery.
But then again. The rocker arm is €79,90 and i've never broken one on any bike. Combine that with this being placed higher and i'm not spending €180+ to protect a €79,90 part that i expect might never be seriously damaged in the first place.
The material used will not tear or break. It is simply too flexable for that and it slides really well (notice how rounded it is so it will not hang on to stuff). We have the same kind of material on our Beta's wich have seen a lot of violence as well (and don't have any damping underneath it) and still the material always stays intact. However we see the frames being bent flat due to it not absorbing enough power. Same happens with the steel versions friend of us had. However they add the extra benefit of tearing of the mounting point so it's welding O-clock.
The question with all bashplates from nilon like materials is not if the bashplate will survive, it just will. However it's the amount of force it can take without temporary deforming so much the protected area is hit. That is where the Stark shines with the foam instert. All the other brands have their bashplate hard mounted and the material doesn't matter if the force is fully transmitted.
I have my Stark for almost 2 years now and just replaced the battery under warranty due to something in the cells. Looking at the bashplate and the foam i will order new foam before next Hard Enduro season. It's not junk now, but you can clearly see it is somewhat deformed and will not absorb the same amount of force. But i think i can bear the financial burdon of having to replace a €29,90 piece every 2 years.
I would love to see someone taking a stock bashplate (from Stark, Beta or whatever) and working it with a sledgehammer and all kinds of violence. I think you'd be shocked by how much and well directed force it takes to do any damage. Do the same test with the more rigid alternatives and be amazed by how little it takes to deform of crack them.
Also a nice thing i've noticed is how much more plush comming to a standstil on some concrete is with the damped Stark compared to the undamped Beta. Significantly less shock force on your arms and knees. And if your arms and knees can feel it, the construction surely can as well.
In my opinion damping is the solution to forces from bashing into things. Not just more ''strong'' protection. Have been talking about that way before the Stark saw the light of day.
HITNRUN
Lorton Va
Well this is all great info!! I’m really glad to read you’ve been hitting it hard for two years now without fail (well battery) 🤔. It’s seems I’ve de-railed the original topic with all this. Sorry for that Erwin!
I have a lifetime of experience on Ice bikes but new to the Stark or any electric to be honest. I will admit, it’s shocking how well I’ve quickly adapted and love to ride it. I will be riding ICE tomorrow due to going way up in the mountains but my last 6 rides have all been on the Stark. There’s so much to like about. Easy comes to mind and at 59yo I think I deserve a bit of that! I have last than 40 super fun hrs on mine so far.
Butt……..
I hope for one day soon a much lighter weight before any extra gear, batteries that will truly last 500 plus hours, and double the current range at minimum. I’m paranoid about the battery because I have a buddy who rode mine 2 tips and liked it so much he went right out and bought one. Well only 2 hrs in and I had to pull him out of the woods with a strap. That sucked!! Now it’s in the shop currently and Stark is saying full battery and maybe more. Totally went dead from 50% charge. We will see. I felt so bad for him. He’s beside himself.
I routinely blow through a full 100% charge on my gen 2 (6.5 kw) MX in 3 (six) mile fast laps of single track with just enough juice to make it back to the generator. At other locations less demanding I might make 24-28 miles taking it more easy. Or with way less hills etc. Butttt…
On any of my Ice bikes I can definitely go way way farther (at-least ) 35- 40 miles of high B to low A vet race pace. This is east coast tight woods with a fair amount of grade changes but nothing crazy like where I’ll be tomorrow.
Anyhow I’m a recently new but HUGE FAN so far overall of this bike!👌But if they can iron out the above 3 things, I think you will see a massive shift here in the states where currently not everyone are feeling it just yet. Well at least in my crowd which consists of 3 separate rides clubs with lots of members in each. Just being brutally honest BTW.
Well the topic was derailed, but knowledge and viewpoint were shared so that counts as a win doesn't it?
I have had some failure point over the past 2 years. Altough it is one of the first bikes though (just under number 1200) so i can forgive them for that. A lott of failure points we had back then are now solved on newer bikes. And lets be honest, my ICE's are far from failure proof as well, before the Stark took up a big chunk of the riding i spend +- €1800 a year only on engine maintenance. So far on the Stark it has been 1 can of oil and a few copper washers (and some hours when replacing the first Powertrain, but that was on me wanting to do it myself).
This battery was actually still working fine. But with an app from a resident from this forum i found i had 2 dead cell groups. My warranty runs out in a few weeks so i claimed a new battery before that. That powertrain also worked well, but tiny cracks started to form in the plastic cover (the early plastic cover versions did that).
Sure there are plenty of things about this bike that could (and some should) have been better. But compared to the competition i still think it's a reasonable deal at worst. Sure it lacks the range of the ICE's but it does offer a lott of comfort and confidence when that range is not needed.
Back to the sidestand, that sure is a bloody shame on this bike although the last version with ''double wall'' construction seems to be working a lott better.
Together with the red tubes it are the 2 long lasting fails of this bike that should have been easy enough to get right.
Back on topic:
New, adjustable kickstand from NiceCnc:
how do you tell Stark that you know the bike had 2 dead cells groups? since you shouldnt know that i wonder what your approach was and if they were surprised
I didn't. I didn't lie either though.
It started to take longer to charge the last few percent and that would drop of faster. First i didn't think too much of it. However with that app showing the 2 dead cell groups it really got my attention. So i told them that without mentioning the app.
They reacted with some questions wich again i answered without lies. The they planned a video call, asked me to put it in standby so they could collect data and told me they would get in touch.
They did tell me they ''saw something'' and told me the bike needed a new battery, wich my dealer got some while later.
The app is really useful... I'm not sure if you meant that two cells or two groups of cells were faulty. I don't know the exact number of damaged cells, but if it was only two, I find it curious that you noticed such a significant decrease in range, considering the bike has a total of 400 cells, 200 on each side of the battery.
I'm also noticing reduced range on mine and I'm getting paranoid. I don't know if it's just me or if it really does have less capacity; I need to keep calculating it more carefully, but I'm noticing it's using more consumption on roughly the same routes.
Stark tells me the battery is in good condition, so I have to believe them. I'm glad they took responsibility and replaced your battery, because they could have lied and said it was fine, since we shouldn't supposedly have the app from the forum member and access that information. Stark could have played dumb over just two cells. But of course they are a serious brand. I know a lot of other brands that could have played dumb and not only on the motorcycle industry.
