Stark ex or 1.2
I did and it said go to product page and all I can find is click for dealers in your area .
Is that on the main site https://starkfuture.com/ ? When you select EX, MX 1.2 or SM in the upper left hand corner, you don't see the below page to select options and then click the 'Order Now' button to put it in your cart? You may need to have a user ID created to complete the order, but even when I'm not logged in, I can build any of the three bikes and put in cart.
fe501tired
ca
I thought that when it said order now it meant it to be one of the bikes they had in stock and then after I hit the order now button then you can add the options. Thanks
every time I go to order my bike online I can only start my options with tires.
Seems like your user interface is displaying odd. Try a different device and/or operating system or browser. Or even just turn your device 90 degrees to see if that shows interface better.
fe501tired
ca
I just have to use another device and it worked and from what I have came up with on my ordering is a mx1.2 is 12.400 with a 18 inch rear tire with the mousse and a side stand heavy susp setting and standard seat and pegs no titanium and lefthand brake. The same bike but in the ex version is 13.280
let see what taxes do you have in your country because my EX was 13.049€ but i got less % of taxes than Barcelona (Spain) and the bike end up in 10.700€
you can contact them and theyy will provide a final invoice with your information, they do that to me
good luck
