fe501tired
- ca
I did and it said go to product page and all I can find is click for dealers in your area .Ask SAM for help?
They do? I know the new SM does, to account for the small front wheel, but thought the mx and ex were the same since same front wheel/tires diameter.The MX has a different rake than the EX if that matters…
That's due to the front suspension being slightly shorter on the EX.The MX has a different rake than the EX if that matters…
I thought that when it said order now it meant it to be one of the bikes they had in stock and then after I hit the order now button then you can add the options. ThanksIs that on the main site https://starkfuture.com/ ? When you select EX, MX 1.2 or SM in the upper left hand corner, you don't see the below page to select options and then click the 'Order Now' button to put it in your cart? You may need to have a user ID created to complete the order, but even when I'm not logged in, I can build any of the three bikes and put in cart.
Seems like your user interface is displaying odd. Try a different device and/or operating system or browser. Or even just turn your device 90 degrees to see if that shows interface better.every time I go to order my bike online I can only start my options with tires.
let see what taxes do you have in your country because my EX was 13.049€ but i got less % of taxes than Barcelona (Spain) and the bike end up in 10.700€I just have to use another device and it worked and from what I have came up with on my ordering is a mx1.2 is 12.400 with a 18 inch rear tire with the mousse and a side stand heavy susp setting and standard seat and pegs no titanium and lefthand brake. The same bike but in the ex version is 13.280
