Molicel Tech (Stark Battery Thread)
This might be suitable for battery enthusiasts like us.
Well, I think many probably already knew this, but I wanted to create a thread dedicated to this Molicel technology, which Stark will likely be working with for a long time.
From what I've been researching, the new P60B cells have been available to the public since the end of August, after the testing period.
They belong to the same category of 21700 power cells; the capacity has increased from 5000mAh to 6000mAh and from 18Wh to 21.6Wh. The voltage is the same under nominal and charging conditions, but the discharge voltage has decreased from 2.5V to 1.8V. The charge current has also increased from 5.0A to 6.0A under standard conditions and from 25A to 30A at maximum.
Now I'll comment on what has disappointed me about this new version. A few months ago I read that the P60B cells had the same weight but more capacity (not true, I'll talk about this later). So, considering that the P50B cells have 260Wh/kg and weigh 70g each, the calculation would be to multiply 70g x 400 cells = 28kg, not counting the magnesium casing. Now you multiply 260Wh/kg x 28kg = 7,280kWh, which is the current capacity of the MX1.2, EX, and SM models. If we do the same calculation with the P60B cells, assuming they have the same weight of 70g but a higher gravimetric capacity of 280Wh/kg, the result would be 280Wh/kg x 28kg = 7,840kWh. But the problem is that the weight of the P60B cells has increased by 5g, so the calculation is no longer based on 28kg but on 30kg if we leave the battery with the same number of 400 cells.
This would give us a capacity of 280Wh/kg x 30kg = 8,400kWh, which would be very good but at the cost of 2kg more weight.
For some, this will be a problem, and for others, not. I don't see it as so relevant for the SM model, but it is for Enduro and motocross.
On other websites, not the official Molicel site (I'll attach a screenshot), they say that the P60B batteries have 288Wh/kg instead of 280Wh/kg. Here, we would have more leeway to achieve 288Wh/kg x 28kg = 8,064kWh by removing some cells instead of all 400. And that would be really good. Or, we could keep the extra 2kg and obtain 8,640kWh with the 400 cells. This configuration would work well with the new ALG model and the other Adventure projects that Stark has, where the weight can be increased without being a problem. They could even have greater capacity and weight; the limit will be set by Stark with his lightweight philosophy. I think Stark failed on not waiting for the P60B for the SM model, maybe they didnt want to wait for some more for so many reasons.
Molicel says their goal is to increase the capacity of their cells by 10% per year; let's hope they can achieve it. I can't wait to have at least 360 Wh/kg and, with the same 28 kg weight, reach 10,080 kWh of capacity. A DREAM!
SCREENSHOTS BELOW:
Web where it says 288wh/kg instead 280wh/kg, i think oficial Molicel info should be more accurate
P60B weight 4 g more than P50B so that's 1.6 kg for the 400 cells pack.
What we know for sure is that Stark prototypes (ridden during their huge media days) had Molicel P42B (4.2 Ah), MX1.0 production bike has P45B (4.5 Ah) which increased capacity from 6.0 to 6.5 kWh.
Newest 7.2 kWh pack used in EX, MX1.2 and SM is made of 5.0 Ah cells, increasing capacity to 7.2 kWh. We don't know who the supplier is, Wass just said that it wasn't Molicel anymore. Still wondering why they don't mention the supplier, it would be good publicity for them and they were happy to have Molicel stickers on their MX1.0 race bikes.
Main point is still relevant, in a handful of years 21700 cells went from 4.2 to 4.5, 5.0 and now 6.0 Ah, any e-motorcycle manufacturer effortlessly benefits from capacity increase every couple of years.
Next generation 400 cells pack using 6.0 Ah cells should be 8.6 kWh for a minimal weight penalty. An adventure bike could carry double pack for serious range with 17.2 kWh (about what Zero motorcycles make).
I guess for street motorcycles (not MX nor enduro) the big question is do you wanna go big (pack) or fast (charge)? Bikes with onboard CCS charger (like Honda WN7) should be able to charge really quick (though the charger is bulky).
oh yeah i knew about the p42b and p45b and i could swear i read that the new 7.2 pack was Molicel p50b, so everything I said isn't very relevant now... Molicel is top-of-the-line right now; I don't know what other brand Stark chose, but the cells must be practically identical to Molicel. I don't really care about the brand; what matters is the capacity and performance of the cells.
If they can reach about 8.6/9.0kwh (ideally 10kwh but that's at least 4 years away) with the same weight for the future EX 1.2 in 2 years, that could be amazing. Also to compensate the increise charging time due to the increased capacity, battery technology needs to reduce damage from fast charging so you can maintain the 2 hour charging time at least.
Newest 7.2 kWh pack used in EX, MX1.2 and SM is made of 5.0 Ah cells, increasing capacity to 7.2 kg. We don't know who the supplier is, Wass just said that it wasn't Molicel anymore. Still wondering why they don't mention the supplier, it would be good publicity for them and they were happy to have Molicel stickers on their MX1.0 race bikes.
also where Anton said that? do you have a Link? Thank you in advance
If we trust this AI response (attached below), it seems they created the cells themselves. It turns out they're now experts at making batteries too, surely with significant help from another company with expertise in the sector.
They'd better have developed 6.0Ah cells and higher for the future; they have a lot of competition.
Well, please excuse the inaccurate information, but you get the gist of it. We can continue discussing this topic if we ever get more information about Stark's proprietary battery and its future advancements.
Assuming the orginal MX 1.0 used P45B cells and assuming that Stark could go back to Molicel for some future models, here is a recap of the numbers; the numbers in orange font can also be found on the official datasheets linked below the table:
P45BP60B
nominal cell voltage3.63.6
capacity (Ah)4.500 Ah6.000 Ah
capacity (Wh)3.6 V * 4.5 Ah = 16.2 Wh3.6 V * 6 Ah = 21.6 Wh
weight (g)7075
gravimetric energy density16.2 Wh / 0.070 kg = 231 Wh/kg;
on Molicel's datasheet 242 Wh/kg
21.6 Wh / 0.075 kg = 288 Wh/kg;
on Molicel's datasheet 280 Wh/kg
continuous discharge current45 A60 A
max power from a 100S4P100 * 3.6 V * 4 * 45 A = 65 kW = 88 hp100 * 3.6 V * 4 * 60 A = 86 kW = 118 hp
capacity from a 100S4P100 * 3.6 V * 4 * 4.5 Ah = 65 kWh100 * 3.6 V * 4 * 6 Ah = 8.6 kWh
weight from a 100S4P0.070 kg * 4 * 100 = 28 kg0.070 kg * 4 * 100 = 30 kg
P45B datasheet
P60B datasheet
Now, let's set an equation to find out a new cell configuration to get 28 kg from P60B cells: with 4 rows in parallel: 0.075 kg * x = 28 kg / 4 → x = 7 kg / 0.075 kg = 93, so you could have a 93S4P setup.
The nominal voltage of the pack would become 335 V, that I wouldn't like since usually you want to get power from higher voltage and lower current so that there are less heat losses and you can also use thinner cables that save some weight. At that point, to get 30 kw which I think is a typical peak value for MX you would need 30.000 W / 335 V = 90 A (the pack could supply 60 A * 4 = 240 A), while with a 360 V battery you would need 83 A. Since the power lost to heat = I² * R, then the power lost to that heat would have increased by a factor of 90² / 83² = 1.18, which is a downgrade. I think that a low voltage is something that can be acceptable for a DIY conversion project, not form a premium bike. Calculating the R is not something that I feel like attempting at the moment. Anyways, can the motor, the inverter and the charger be used with those lower voltages?
Using a 3P configuration would mean 0.075 kg * x = 28 kg / 3 → x = 124, so 124S3P that would mean 446 V and 500 V at full charge; again, could they use the same motors, inverter and charger?
No worries for the capacity, since the gravimetric energy density would be improved, so for roughly 28 kg you would get 28 kg * 280 Wh / kg = 7.8 kWh in both cases.
Maybe one of the reasons for which they changed cells supplier is that they wanted to keep a similar voltage and that with the 3.6 V, cell weight and other specs that the Molicel cells have they couldn't find a configuration that suits their needs. The MX1.2 is rated to have a 420 V battery, while the technical specification for the 1.0 from their site is a voltage range from 250 V to 420 V, i guess depending on the SOC.
I'm pretty sure it was a video interview, can't recall which one. IIRC, he said they changed supplier, they had been shopping around and tried multiple cells and simply chose the best one for their use case.
It might be in this interview :
Sorry it's just AI BS, Stark certainly don't make their own cells, it would be far far far too expensive to get into this business, start R&D from scratch and hope to equate (not even mentioning beating) established industrial giants at their own game. Honda has the industrial might to do that, not Stark.
Molicel or not, it's still an interesting discussion. It's quite amazing really that the biggest hurdle faced by EV makers (range) improves continuously and significantly without any effort from said EV makers, it all comes from suppliers investing so much in R&D to keep pushing the limits. Whenever some supplier releases 6, 7, 8 Ah cells, it's just Christmas time for Stark and the like.
Yes, at 6:04 (found it quickly by doing a search in the video transcrpit).
It sounds weird to me too that Stark would ever make their own cells. What I've understood from that screenshot is that they make their own pack, not the individual cells, though. Like they make things like the BMS and the case.
Amazing indeed; maybe that's one of the reasons for which you see a lot of EV startups but few ICE ones.
i remeber seen that interview, that video has comments of mine 7 months ago when i was pissed off by the delayed deliveries of the EX hahahaha i was desperate waiting on mine... i dont remember Anton saying that, i will watch it again... but i trust you and the analysis you make is pretty logical, they are not HONDA.
EDIT: @Theo found it, Anton just says NO to all questions hahaha Enforcer do very good questions
The thing is, more or less all manufacturers are going to keep the same pace with cell advancements, so based on what Molicel is releasing, we can get an idea of the current market situation. Stark has probably used cells practically identical to the P50B for their latest models.
Bernardo
news from molicel…
The INR-21700-M65A battery delivers exceptional performance with its 6500 mAh high capacity and 322 Wh/kg energy density, packing more power into a compact design. It offers an extended cycle life of over 1000 cycles for reliable, enduring power, along with a 30% increase in driving range, 40% improved reliability, and up to a 30% weight reduction.
news from molicel…
The "M" models are the "Medium Power Cell" models, the P60B are the "Power Cell" models which i think are the high performance cells that will work better on a high power EV Vehicle or "device".
I'm no expert, but looking at the specifications, even though practically everything is superior in performance and at first glance it seems like a suitable cell for Stark, I see a notable difference in discharge capacity, which is only 26.0A compared to the 60A of the P50B or even 100A on the P60B, which isn't the one Stark uses, but it's very likely they have a very similar one.
The P45B already had 45.0A and it's a cell that Stark did use in the MX 1.0. With such a low value, I don't know if it's optimal for a Varg, since it needs a high discharge capacity to handle all the power it has, and perhaps its use is limited for this bike.
The 322Wh/kg is very good, could give us a 9KWH battery capacity with a minimum weight penalty
That's right, M65A and P60B had been announced by Molicel at the same time back in June, see here:
Yep, Molicel say it himself: "(the M Series’ high capacity is specifically designed for extended range, making the INR-21700-M65A ideal for a full spectrum of e-bikes where longer mileage is key. In contrast, the P Series is engineered for power, with the INR-21700-P60B specifically targeting high-end MTBs (electric mountain bikes) that demand maximum output and acceleration.)"
"Alongside the INR-21700-M65A, the Molicel INR-21700-P60B is engineered for the extreme power and range demands of MTBs. Its unrivaled 90A discharge current delivers instant bursts for MTBs,cross bikes and dirt bikes, conquering steep climbs and rough terrains smoothly. The INR-21700-P60B boasts a low internal resistance of 12.8 mΩ, a 14.7% improvement with minimal temperature rise"
P series are good in range too but built more specifically for power output, thats what i was refering earlier with the higher Discharge current, the M series has higher capacity but poor Discharge current of 26A, not ideal for a Varg. P series are the way to go.
I don't think we'll see a new Stark battery until the launch of ÄlG, or a future EX 1.2 with 288Wh/kg or maybe 300wh/kg "Stark cells". But it seems Molicel leads the market in capacity; let's hope that whoever Stark collaborates with for its batteries will be on par.
An AI has just found us this article that explains the typical tradeoffs between cells that are more energy dense like the M65A and others which are more power dense like the P60B. In short, for energy density you try and "squeeze" into the cell those materials that hold charge -the active materials- as much as possible, but in this way the current flow will be hindered because of the lower cross sectional area of conductors, i. e. the current collectors, while for power density you will have better current flow. The flow of the electrolite, that is liquid, is also important to achieve better ions flow, that's why the electrodes are more porous in power cells.
For all the battery geeks out there, take a look at Batemo website.
Here is an overview of 5 Ah 21700 commercial cells.
Molicel P50B is 2nd from the bottom in energy density... but it's 4th best when it comes to power density (most are about half of it, Samsung 50S are closer).
Power champions are Reliance RS50 and Highstar 50PS (with equal or better energy density than Molicel P50B).
Of course, energy density and power density are great for spec sheets but cell degradation and thermal limitations under intended use are paramount. No doubt Stark took some time to test that.
Please note that peak power is referenced for Batemo as power sustainable for 5 min (which is an unlikely scenario for motorcycles).
Hence they give Molicel P50B peak power at 136 W while Molicel states max power at 397 W (10 s, SOC 100%, 25 °C) and 228 W (10 s, SOC 50%, 25 °C). Max continuous discharge current of 60 A gives power of 216 W at nominal voltage (3.6 V).
Anyway, to make 80 hp (60 kW) with a 400 cells pack, one cell needs to supply 150 W peak power, which eliminates A LOT of potential cells.
Molicel P50B can supply that for a few seconds, Reliance RS50 and Highstar 50PS can provide that for at least 5 min.
Furthermore, using cells like Reliance RS50, peak power from 400 cells pack would easily go over 90 hp (provided the motor, BMS and the rest can handle that). Max power would likely be higher, in the 100 hp range, given it's reaching 90 hp with power sustainable for 5 min.
Ya shit in equals shit out. Artificial google is no different than actual google. Its crap whether manually cut & pasted from some reddit post or if a dumb machine does the cut & paste.
