- Austria
Yes, but the reports I've read were that the adapter was not unlocked which could lead to several issues, Don't forget the charging station provider has your data so you could be made liable for all kind of physical and financial damage if just leaving the adapter there. And if you call for help and stay the same would probably apply.That said, using the Stark portable charger will always allow to unmate the connection under load since its mains plug does not have a locking provision - using an adapter or not.
