Stark throttle/hand grip
fe501tired
ca
I wanted to ask other riders of the Stark how they grip the throttle It seems for me I have to way over grip the throttle to keep my elbows up where there supposed to be so when I give it full throttle but hers the problem when I chop the throttle my hand is way too far forward not giving me the ideal position to grip throttle when slowing down and it gets sketchy the only way I could fix this is either set up a custom map where full throttle comes on much earlier or ramps up faster if that makes any sense or if there was a aftermarket throttle that had less rotation to reach full open, let me know what you guys think but I do know it helps big time if I turn the power way up like to at least 40 plus hp and it also makes it easier to pop front end up please comment on this thanks Robert
Personally, I struggle in general to keep my elbows high and I fell discomfort when I need to twist my wrist much. I can't customize maps yet on my MX 1.0 and one of the reasons I keep power settings probably higher than what I need is that by doing so I will get the power I want limiting the right hand rotation. I have this problem mainly when standing before jumps.
Are you riding with a finger on the front brake all the time?
There is no aftermarket throttle available (yet) that would accomplish this and basically this wouldn't be necessary as Stark could do that electronically within the setup. Unfortunately they decided not to offer that until now even though it seemed to be an option for a future upgrade - maybe some time.
What you can do though, is change the virtual throttle play - basically that slightly changes the position of the magnet in regard to the throttle stop at idle and will cause a more immediate reaction to twisting the throttle grip. This makes quite a difference in how the power comes on and to an extend also on how far you have to twist for WOT. Obviously this is a bit of a hack and you should be quite confident in your mechanical skills before attempting that on something as crucial as you throttle!!!
This is not the stock throttle tube, but a Berm lock on adapter on an ODI throttle grip, but the same principle applies to the stock unit. The farther out you turn the screw, the more immediate the pickup will be. Nevertheless if you go too far the Varg will not let you start up the bike and display a constant red light for a throttle input error.
Yes standing makes it worse
I rarely cover the front brake anymore mainly just my rear brake with the hand lever with one finger as I can easily lock up the rear tire with one finger and as I'm learning my ways with this bike I find running 40 plus hp with about 50 to 60 rejen braking basically more power more regen that makes it so I am not having to go wide open as much . then I'm hardly braking much and also where's that screw on the stark throttle thanks Robert
I keep finding myself re gripping the throttle but again when I turn power way up seems to fix it since less twist
So just for the hell of it I asked Sam from Stark future and he/she said to loosen throttle clamp and rotate throttle back or forward to my liking which makes sense so I will try rotating forward a bit .
Hmm, I don’t see how rotating the throttle on the handlebar would change anything?
I ride strictly Enduro/hard Enduro trails but like others have said I run a higher horsepower than I really need (52 HP) and I just barely open the throttle most of the time. If I want a strong blast of power, I can crank more of the throttle, it works so well for me, I am no longer interested in any custom mapping nor clutch.
That's part of the reason I'm very skeptical about AI answers in technical aspects - the chance of a miss is so high that you need to doublecheck anyway which in turn makes asking the AI firsthand kind of useless ...
changing its orientation will do exactly the same thing as changing your grip position. closed and wide open will still be the same distance apart. I too would like a lets say 60 degrees rotation instead of a 90 degree rotation (or whatever it currently is). I find that if I overgrip so my wrist is straighter and more comfortable with the throttle open, then i'm more prone to whiskey if something sends me towards the back of my bike.
I agree on the higher hp setting it makes it much easier to crack the throttle to get the front wheel up and over things
I hear what your saying, I didn't set up the bike or build it I bought at a dealer so they just probably did not think about proper set up as far as throttle tube position on the bars which I understand everybody is different I just want to rotate the throttle tube clockwise a little bit so when I'm wide open my arm and elbow are not aiming towards the ground so much that way im not over gripping throttle so much
When you challenge Sam with questions that potentially could strain Stark Future business practice, you'll get this
yadda yadda, contact someone who won't give a satisfying answer after a long wait (I'm not a certified translator)
  • there is a Kontaktseite
  • but there are no managers to find on the Kontaktseite
What ever comes from Sam or human support is designed to get rid of your 'pesky' problems or questions as quick and easy as possible, ideally leaving you not complaining. Stark Future is a business, and businesses don't have friends - except for the CEO.
That Sam is the status quo of a sitemap; ie. it doesn't have more value than retrieving information that is published by Stark somewhere. It will offer to open a ticket on something considered individual, but it will crash on something they won't like to be bothered with.
