QS138 70H stuttering
Helienduro
Costa Rica
I finally finished my build including an EBMX X9000 V3 controller and harness paired to a QS138 V3 motor and a 72v 60ah battery mounted on a 2014 TM Racing 450mx chassis.
I did the full setup as required and everything worked fine, then I took the bike for test ride but unfortunately when putting it under heavy loads, it stuttered and made horrible noises that had me thinking I had broken the gearbox.
I inspected the gearbox and it was perfect (it’s the newer, reinforced with bigger bearings and a CNC cover from Electro&Co) so I did a search and found that sometimes the phase wires, specially under heavy loads, might produce EMI (electro magnetic interference) to the sensor wires and cause stuttering.
So I separated the sensor wires from the phase wires as much as possible (I had them bundled up together before) and I also eliminated the sensor-wires plug-in connector and instead welded all the wires directly to the controller, as several people recommended. I also recalibrated the controller in case it was a controller setup issue.
I then took the bike for a ride and it was much better, almost perfect. Only occasionally and for short bursts did I get stuttering, but again, only under very heavy loads like starting up a steep hill from zero or near zero speed. The rest of the time it ran beautifully.
So, it seems that the problem might be EMI related and I read that adding ferrite rings to the phase wires might help. I ordered some and hope the problem gets resolved, but I would very much appreciate any advice and/or suggestions.
Otherwise the bike is a dream, beautiful aluminum chassis with great suspension (KYB forks with JBI kit and a TM brand CNC shock), it weighs less than my YZ250 plus, and as you all know, nothing beats electric power delivery! Thanks
Sweet build! Love that TM chassis, such cool bikes.
I don't have direct experience with the qs138 and emi, but at my day job we use braided sheathing to eliminate emi from position sensors on our electric motors.
We have measured the emi with a picoscope and saw a significant reduction using braided sheathing that is grounded. This could be a next step if your ferrite chokes don't work.
Here is an example. Amazon sells it.
I also read about the grounded sheathing but didn’t think much of it, but I’m definitely not knowledgeable enough so I’ll follow your advice. Hope that works. Thanks a lot .
And yes, I was very lucky to find a TM rolling chassis. They are amazing, hand built (crafted I would say) Italian bikes. Thanks again.
I have the same controller and the same studdering problem - it happens in a hole shot situation every time - full acceleration with good traction - if I lower the power level it stops - I will try the sheathing, do it put it on the sensor wires or the phase wires.
Sensor wires, You want to shield them from the interference.
I was about to ask the same question. The ferrite beads I know go on the phase wires, as close to the controller as possible, according to my search.
I installed 6 ferrite beads on the 3 phase wires, 3 close to the controller and 3 next to the motor. It made no difference. I am waiting for the wire shield to install over the sensor wires, following El Duderino’s advice, and hope that resolves the problem.
I separated the sensor wires from the phase wires like Helienduro mentioned above, it made a big improvement but didn’t totally solve the problem. Lowering the max power setting seems to eliminate the shuddering. So I think i am able to just live with it.
Thanks for the set up tip.
I installed a grounded braided shield over the sensor wires and the stuttering diminished quite a bit but is not totally gone. I wonder if there is a setup or coding issue between the X9000 and the QS138.
I had a FarDriver ND961000 controller on the same motor and sensor wires were right next to phase wires. I never had a shuddering problem, I had random cut out problems which were far worse, but never motor shuddering.
I have run only Votol Controllers and they sometimes have shuddering. But there are certain flux weakening parameters that a manual says to fix that problem, and we have always been able to eliminate it by changing those parameters. Here is a single sheet of what to adjust this out.
I lowered the field weakening setting to 25% on the EBMX X9000 V3 and sensor wires separated from the phase wires - a big improvement but full power starts (hole shots) with good traction still shudder the motor.
