Trialsman
- Pittsburgh
I have a 2017 MX and the dealer in GA told me the charger could operate on either 110v or 220v although it was currently wired for 110. The cord and the label on the charger are for 110v/220v but it is three wires, yellow/green, black, and white only. The dealer in Pgh said it could only operate on 110v.
So which is it ??????????
I want to wire it for 110v if I can't find a 220v outlet but wish to use the 220v dryer type outlet I have for my welders. Do I then rewire with two seperate wires (one 3-wire and one four-wire) all the way from the charger unit? Or should I take four-wire up to the GFI and run two pigtails plus a ground from there? The charger is Alg 1000 312V2K5W 389V8A
1400/2420 E5789 built 11/8/16. Thanks for your responses.
