Alta EXR Auxiliary 12v Power
RangerRyan
Metcalf Motorcycle Park
Hello,
I am currently sourcing parts set up 3 Alta EXR motorcycles with emergency lighting and sirens. My biggest concern is being able to pull an additional 60W or so from the factory wiring. Does anyone know if there is a way to safely supply that much power at 12v from the factory wiring or am I going to have to run this system off of a separate battery?
Thanks,
Ryan
The system is very sensitive to variations in load, I suspect for the power requirements you are talking about you will have to go the auxiliary battery route. There has been a lot of discussion on this subject on here previously you can catch up on. A couple other guys have ran some tests on the various circuits to try and see what the limits were, hopefully they can comment further.
Redwolf
My dog thinks I'm cool
Brinnon, Wa.
Emergency lights and sirens?? This sounds like an interesting use for an Alta...
Care to share the back story, or will we be allowed to speculate wildly?
