Ok because of the current status at Alta I decided to get an Alta LHRB setup. Mainly cause the rear brake pedal is a pretty hokie piece. I will have to move my rear brake light switch to the front brake MC banjo bolt as the Alta rear setup removes the place for it. Luckily sicass makes one with a 90 bend on it.
I have done this once before way back when Rekluse had the option for handlebar rear brake probably 12years ago. I went all in and removed the the foot pedal too. I think I had to on the early rekluse kit like the Alta kit.
I quickly went back to pedal. If I remember correctly it was weird not having a place for my foot to rest. I also drag my rear brake a lot with my foot probably a bad habit. I really don’t think I gave it enough time to learn it.
So my question for the group is anybody use the handlebar rear brake lever only setup? And in mostly single track technical riding but at a good clip did you eventually like the setup better than the rear pedal way. Trying to decide whether to put the kit and switch in my Alta spares for when pedal breaks off or put in on now and start learning the new way.
