Alta Maintenance Items Quick Reference
Butch
Poseur
San Jose, California
Fork seals, oil, gearbox coolant stuff like that.
The information seems to be scattered around in all sorts of posts. I would like to put it all here, In the first post of this thread.
I will list stuff as I find it again
Brake Pads F KTM p/n 503130030 000; EBC MXS181
Brake Pads R EBC MXS368
Brake Lever
LHRB lever KTM p/n 5480 2031 000
Brake Fluid DOT 4
Fork Seals WP R14046-01 48mm
Fork Oil
Shock Fluid
Footpegs
Footpeg Springs
Coolant Prestone Glycol 720 ml
Gear Oil SAE 75-90 120 ml
Sprockets
Wheel Bearings
MX F , R
EX F , R
SM F , R
Mudflap
Front Fender Collar Bushings
2009 Honda CRF450R A FRONT FENDER | Babbitts Online
threads for reference
4CS fork oil levels?
Fork Seals p/n
Butch
Poseur
Awesome. I will copy all relevant contributions to the first pane of the thread.
Edit: I might make a mistake, so doublecheck my work.
Butch, another common wear item you may want in your list are the wheel bearings. I had made a post with some various bearing and seal options HERE if you wanted to review and add any of that to your list.
SF Bay Area, CA
Don’t forget to top off the roost tank. Some riders go through copious amounts of roost during a ride, especially off of the starting line. (Just ask whoever is following @Fog 25). Don’t run low on roost or the other guys will think you are on a regular gas bike and have to do pansy stuff like shifting. A constant stream of painful roost chunkage slamming into their vulnerable frontal areas will keep your foes far behind, and your friends farther. Stock up on old favorites like “dirt clod” and “pea gravel” or “stinging sand.” Just make sure it is all rated for industry standard Map 4 Roost output velocity. Some people prefer extra chunky style over smooth & stingy, but that is just rider preference.
Fog 25
Castaic ca
Check out my Roost victim posts. You can see the damage🙈
Butch
Poseur
Philip, can you give me edit power? I want to put this
Brakes
- Front and rear brakes and brake pads are from 2014 KTMs
- Front -- MX/MXR/EX/EXR - Brembo - Part common with KTM SXF 450 brake master and caliper. SM - Brembo - S1000RR pad material and caliper. Can be retrofitted with aftermarket Brembo kit
- Rear -- All models - Brembo,
and this
check here too
List of aftermarket products for the Alta
in the first pane...
Hope all is well wherever you are hiding from the beer flu.
Butch
Poseur
I wood be be happy to put the meat of this iin the first post, but modpowers have I not.
wheel bearing replacement. There was a previous discussion on the front bearings (edit ) Replacement wheel bearing kits .
"Several members have had what I would consider premature wheel bearing failures now, the causes are debatable, but this information should help for sourcing the replacement parts.
Here are the numbers for the All Balls kits courtesy of @OneLapper . The Alta uses the same rear bearings as KTM's with the smaller 20mm axle OD.
All Balls Rear Wheel Bearing Kit
All Balls Front Wheel Bearing Kit
These following bearing kits features Italian SKF bearings and seals. It also includes new hard anodized spacers which should perform significantly better than the OEM Alta/Warp 9 wheel spacers, unfortunately only the rear spacers are the same as KTM and can be used. The front spacers would not work for a stock Alta.
Inntech Rear Wheel Bearing and Seal Kits featuring SKF components
Inntech Front Wheel Bearing and Seal Kits featuring SKF components
The SKF seals in the Inntech kit have a floating outer seal that should drastically reduce grooving in the wheel spacers.
If you would like to source the SKF bearings and seals separately, here are the numbers;
SKF Rear Wheel Bearing for Altas
SKF Front Wheel Bearing for Altas
The rear wheel seals have an SKF # of WS108 and the front WS109, but I can't seem to find any web links for products, so more digging would be required to source those separately.
Hope this helps you all in the future."
SF Bay Area, CA
wheel bearing replacement. There was a previous discussion on the front bearings HERE.
@Butch , did you mean to put links or part numbers in your post above? Not sure if they came through correctly or not.
Butch
Poseur
Can anyone ID the…
Front brake rotor for a 2018 EX? Anyone know the part number for the presumably KTM thingy? When converting my EX to a SMEXy thing the rotor I got was a little bit out o true…
and my goodness the SMEX is fun. Pretty impractical, but hey, bigfun.
