The 120VAC outs in my van are 15 amp max rating, same as most household outlets, so same speed as if you plugged into your home outlet. Like a few hours. Realize it will only charge at the maximum amps you set in your Stark Varg settings on the phone. I am usually not in a rush so I set mine at 8 amps to be easy on the batteries.
