- Pennsylvania
I just recently learned that a fellow Alta owner has been operating under the idea that the standard charger only runs on 110v, and the rapid only 240v as was explained to him by the dealer. This is only further complicated by the wording on the website that seperarates charging times as rapid (240v) and standard (110v).
I’m going to copy from a previous thread where Alta customer support clarified this a bit in an email;
“Thanks for reaching out, we are stoked that you like our bikes.
Right now we do not have a manual available for our chargers or MXR. For now, while we are working on creating the MXR manual, we recommend MXR customers refer to the MX Manual and reach out with any specific questions or concerns. As far as service work goes, both MX and MXR are virtually identical.
Both our Standard charger ($499) and our Rapid charger ($799) are capable of charging at 240VAC. Note however, our standard charger comes with a 110VAC (5-15 style) plug so you will need an adapter to charge at 240VAC. The R charger comes with a 240VAC (L14-30 style) plug, you will need an adapter to charge at 110VAC.
Charging at 240VAC does not effect the life of the battery any differently than charging at 110VAC
Our battery does not come with a 1000 hr warranty but is expected to last for 1000+ hours. Our complete warranty MX/MXR warranty can be found HERE. Our battery is rated for 1000 charging cycles. Depending on how you ride, each charge can last between 30 minutes (pro moto) and 4+ hours (slow/technical woods single track). This means our battery is rated for between 500 and 4000+ hours depending on how you ride. Keep in mind most riders don't achieve even 100 hrs a year.
Charging at 240VAC is faster than charging at 110VAC. There is not a manual charge speed control, its full charge speed or no charge at all.
I hope this information helps. Thank you again for your interest and support!
Happy Riding and Stay Fast!
Kevin
- Team Alta”
So if there happens to be anyone else out there who thinks their standard charger only works on 110v, you might be glad to hear this.
Kevin
- Team Alta”
