- Lake Havasu City, AZ
UPDATE: the bike charges and seems to operate fine. The code is still there. I’ve ordered the cables for the multitool. While I wait for them I planned to undo and dry any connections I can find. Should I be wearing high voltage gloves for any of the connectors? Thanks, Adam
Yes, but I would encourage you to be very careful. Code 33 is the one code that can kill you if it is real. Clear the code only after having checked you don't actually have an isolation issue.Can you delete fault codes through multitool?
If I clear the the code and it doesn’t return it should be ok correct? If I clear it and it returns then I have a real issue?Yes, but I would encourage you to be very careful. Code 33 is the one code that can kill you if it is real. Clear the code only after having checked you don't actually have an isolation issue.
Gotcha! Thanks! I plan to watch your multitool install video TCMB371 and donate to your channel! Thanks for doing thatCorrect. But as Judaslefourbe mentioned, you should be very careful.
Thanks again man! I found the video. I’ll go through it tonight when I get homeAre you using Virtual Box? Follow my "Use of Multitool" video and it explains how to pass the USB connection over to the virtual machine.
Sorry for the slow update on this! I had surgery and then got an infection so I haven’t been on the bike in quite some time, still not! So I got the multitool up and going and was able to delete the code 33. I loaned the bike to a friend to test out and after about 50 miles the code had not come back! Figured it was fixed. Then one day about 2 weeks ago I walked by and keyed the bike on just for fun and the code was BACK! I haven’t had time to even think about digging back into this thing but I guess that’s what needs to happen. I was going to post something here hoping to find a direction to go.@Trialsbikeadam, were you able to fully resolve your Code 33 issue?
Sorry for the slow update on this! I had surgery and then got an infection...
Thanks man! It’s just about over, I’ll be back riding shortly! Mine runs and operates fine it just has the code. Since it the high voltage isolation code it has me worried. Let’s keep in touch and see if we can’t get this resolved!!!Yikes! I hope you're fully recovered!
I've got a Code 33 on my SM. None of its lights will turn on, and it won't charge. (The display seems to be the only low-voltage item that hasn't had its power cut off.) I'm waiting for the CANBUS cable/dongles I ordered to arrive, before I try to diagnose what's going on.
