querlenker
- Germany
Hello,
i was concerned when i read a damaged display will stop the bike. So i did some research and as mentioned here, simply adding a termination resistor into the can network, won`t solve the problem. I checked this before. Thats why i decided to avoid that scenario for me and a friend and build something. So for anyone with no oportunity to buy an original Alta display, i may have a solution. It will be more expensive but offer also more functionality. Right now it's stil under development, i think i will test it next week on the bike.
- Standart displayed features will be: Speed, Odometer, Battery, Map, Error Codes, GPS Speed, GPS location, Laptimes, Datalogs
- Indicator lights can be included as well, more data like throttle position also possible
- Additional premium features: 3 digital inputs for example for wheel sensors or switches, 3 analog imputs for example front and rear suspension, temperatures or brake pressure
I used the same system on the electric bikes i was involved and will use it on our Alta this year. I will not share the can matrix or special details, so need to ask for, I will help when i can. The system consists of an AIM Solo 2 DL display, which plugs in the Alta harness. For the premium features an additional microcontroller and sensors are added.
The system looks like this (a picture of the mounted Display will follow):
BTW, anyone faster, more milage or Map 5?
