Trialsman
- Pittsburgh
Thanks !!
Pretty obvious, I just removed the headlight to make it easier, unbolted the display from the triple clamps, slipped the vault over the display and bolted everything back together. I didn't use the brackets to mount it also to the handelbar clamp, not sure it is necessary, but can easily do that if needed. I did have to move some wires from the front of the handelbar clamp to the rear, but that was to have enough room for the LHRB line and the wires. Entire install only took about 30-60 minutes and I was helping my son-in-law change the oil in his car at the same time.I presume installation is obvious. This will be the first disassembly I have done to EX006. I have only ridden it, plugged in, unplugged it, ridden again.. and lubed the chain.
I’ve only had EX006 for two months. Previous owner changed the gear oil.What about gear oil changes?
