Hinkelstein
- Germany
Hi, this one looks nice. Any thoughts?
Yes. As the output behavior of the hirschmann throttle is known, it would be possible to build a device with some arduino programming. This could be clutch behaviour or throttle curves, even both. But you are right, what if the device fails and simulates whiskey throttle. Had this once with my em due to a shortcut in the wiring. Not funny.Honestly I would be very cautious with this, thoug:
1-are you sure that it's reliable and that it won't behave incorrectly causing an unexpected power delivery? I doubt it has been developed with Stark and approved by them.
2-it would void the warranty
I think the part looking like a master cylinder is the case for the electronics. But I totally agree, there is a lot more communication necessary to make someone throw 500 Euros at it.How does it work?
Does it interrupt the throttle signal?
If it is an entirely electronical/software method why the need for that big "master cylinder" on the bars?
I'm surprised that someone would make this and expect people to buy it without answering all these questions and more.
Also ignoring the absences of left-hand-rear-brake which is one of the advantages of EVs.
I'd be more interested in a thumb operated device.
Something like this: Inoveli, the new accelerator handle system for ATV, motorbike, scooter, watercraft ...
Interesting. I guess everybody is different. I find the Stark much better for all those things than either my KTM (300 2T) or Yam (450 4T) once you relearn using the throttle as the controller. I ride mostly slow gnarly enduro/hard enduro.I would absolutely love to try one of these out. For me, when riding my gas bikes in low speed situations that require abrupt power delivery, I pull in the clutch, rev the throttle to bring the motor up where I want it to be in the powerband and feather the lever release to match what is needed to clear the obstacle or negotiate the maneuver in front of me. Works like that for me when there's a need for immediate stopping too. I disengage the clutch, use brakes as needed to stop. Standing still balancing I use the clutch-brake-throttle while I consider my next move. I'm having a slow-go-of relearning those techniques on the electric Varg.
So, as much as this product interests me - will I buy one? Not likely. For the same two reasons @Theo mentioned above: Cost and possible warranty issues.
For me, not having to use the clutch removes the clutch-brake-throttle triplet and just makes it brake-throttle removing a control interference and maintaining full power of the left hand on the bars (which is the weaker hand/arm from most right handed people). On top of that there is no chance of stall. The Stark gives all the benefits of a Rekluse without the lever.
Yes, my Varg does have the handbrake. I've also raced MTB for many years and my rigs were (are) always setup with moto-style lever arrangement. So, I thought it would be a pretty easy switch to go that way on the Varg. But, it's not as easy as I thought, I guess my muscle memory knows the difference between 270lbs and 22lbs. . I may convert back to foot brake, but I wanna give it a full riding season before I quit trying. My other dirtbikes are a Sherco ST290 trials bike and 250SX KTM prep'd for woods (18", big tank, Gnarly pipe, etc.). I had a 300 XCW before that, but it felt too soft to me, I like the snappy power and light weight of the SX.Does your Stark have a left hand brake? I could see how that could be disruptive to control if your muscle memory is automatic to that lever and unconsciously treat it like a clutch. For me I opted for the old-school config with a foot brake and single standard front brake lever. I do ride mountain bikes with L&R lever brakes but I did not muscle memory to that for motorcycles and would have trouble getting used to that on my E-Dirtbike.
Cool.Yep, I never did gel with the Rekluse when I tried it many, many years ago either. It felt to me (back then when I was riding at a much higher level than now) like it took away too much control of the bike for little benefit.
I grew up in Attleboro, MA. Left there in 1994 when I was 35 years old. Raced Expert class MX on NESC/District 1 tracks mostly. Rode Observed Trials for 9 years with NETA and enduro A/B with King Philip Trail Riders. Where are you at in Mass and where do you ride Hard Enduro? Most of the KPTR stuff was run out of Wrentham State Forest back in those days.
If they got approval from Stark, it would be a different situation.Honestly I would be very cautious with this, thoug:
