Wnuudiction
- Maui
I tried to have my local shop call Warp 9 today and order the bearing and spacer kit but they said Alta 2.0 won’t let them sell the spacers anymore. Anyone got any they want to part with?
WHAT??! I was late to call Warp 9 by a few minutes today, they just closed. Need to find out what exactly BRP told them.Alta 2.0 won’t let them sell the spacers anymore
The rear Alta wheels are exactly the same as KTM's.I won't duplicate your call to Warp 9, but if you get the chance please also ask them about full wheels in addition to parts. Or possibly wheels that might happen to fit a Redshift w/o the ALTA spacers.
The front Alta wheels have hubs that are wider by 7mm on each side. KTM wheels will fit too, just with 7mm axle spacers and 7mm caliper spacers.
I could make those spacers, should be easy. Need about 4-6 weeks.If anyone has the ability to fabricate the wheel spacers for the front I would be interested.
One just got seized in the inner race of the bearing. I had changed the tire twice, removed the wheel, lubing the shaft every time but I never thought to remove and lube the spacer each time(they were so loose on my previous bike they would usually just fall out), I will now. But to get it out took a lot of heat, penetrating oil and tapping with a socket that mared the inner edge of the spacer. I took the nicks out on the grinding wheel but I just want to have a set for my dirt tires and a set for my street tire.I could make those spacers, should be easy. Need about 4-6 weeks.
Why do you need them, I am curious, and how soon do you need them?
