EXR Battery Control Unit (BCU) Question
VINSANITY
Liquid Performance has battery control units (COATED 2103779-02) for sale on e-bay.
Does anyone know if this will work on a 2019 EXR
Thanks Mark
Can you purchase the contractors somewhere and how are they installed.
Yes, they're commercially available. I know the A pack part number but not the R pack, sorry. However, search the site as I'm pretty sure someone posted the part number somewhere.
VINSANITY
@VINSANITY did your BCU go out or just preparing for worst?
A couple of times after charging everything went dead when turning the key on. It cleared itself after sitting for a while. I have checked the cells either computer and they seem OK.
I think the BCU and or contractors may have a problem.
Contactors are not going to be easy to remove from the lid. From the looks of it the contactors were first installed on the BCU, and then the cavity that they nest in must have had a predetermined amount of some epoxy product applied, then the BCU/contactor assembly must have been set in and allowed to cure. Going to take some careful work to remove so as to not damage the lid itself.4EE64643-566F-4DE6-A6E5-07619D0DDBDB.jpeg
VINSANITY
Thanks for responding - looks like a pretty tricky job
I bought the BCU off eBay and got a price on the contractors from gigavac
I thought I would get the parts and keep using the bike as it seems to be working fine right now
Double check with Gigavac. They were not able (or willing) to match the exact part number when I emailed them for a quote. I gave them the part numbers @Oded supplied, they returned a different part number, I asked for verification that the part was identical, then no reply.
