Ford F-150 Lightning Electric
reeldealev
Tampa
I wonder if the 240v or 120v plug could charge as you were driving, and if they would be able to handle charging an ALTA
I wonder that as well. They show outlets in the front trunk, I’d imagine they would have something for the bed too.
SF Bay Area, CA
Per the article:
“Gas powered F-150s have an available generator that Ford calls Pro Power Onboard, and the Lightning uses a similar system. Instead of sourcing power from the gas engine, in the Lightning it simply drains the battery. It provides either 2.4 kilowatts of power on the base model or a combo of 2.5 kilowatts in the frunk's outlets and 7.2 kilowatts in the cab and bed on the top two trims. The battery's status can be checked in the FordPass app, and it'll send an alert when the charge dips below 33 percent. You can set it up to automatically stop supplying power when there isn't enough range to make it to the nearest charging station.”
