Anyone know the dimension of the helical gears used for the primary reduction?
T testus191 Member Likes 24 Location Poteau, OK Mar 4, 2021 #1 Anyone know the dimension of the helical gears used for the primary reduction?
E enjoythesilenc Well-known member Likes 263 Location virginia Mar 6, 2021 #2 Is it something i can measure for you or are you looking for a technical spec? What are we working on?
T testus191 Member Likes 24 Location Poteau, OK Mar 7, 2021 #3 Not likely unfortunately, I’m curious what the helix angle, pressure angle, and pitch diameter are. Just didn’t know if anyone knew of a tech spec or sheet for them. Trying to make a custom pinion to fit a different motor.
